Question about Apple Computers & Internet
I can no longer convert my Finale compositions into audio files
It gives me an error message that says '' Could not create audio file. Document may be in use by another program''.
I was only running Finale Print Music at the time. There were no other programs running.
  • 126 Answers
It sounds like a corrupt file - not totally damaged - bu ti sometimes happen. You can try some housekeeping - run the disk utility and repair disk rights. Remeber to back up your files first.
Hope this helps.
Posted on Oct 09, 2009
My msword 2003 showing file convertor error in all files my data is v importent pls help me
ARE YOU TRYING TO OPEN WORD 2007 DOCUMENT IN WORD 2003. FOR YOUR INFORMATION, WORD 2003 CANT OPEN DOCUMENTS CREATED IN WORD 2007 FORMAT UNTIL THEY HAVE BEES SAVED IN WORD 2003 FORMAT( YOU GET THIS OPTION IN SAVE AS DIALOG BOX).
You may receive the following error:
Word cannot start the converter mswrd632.wpc
This error is cause because of f the security update for Windows XP, Windows 2000, and Windows Server 2003 on December 8, 2009.
You may experience mail merge issues write files are parsed but no message is shown.
To resolve this issue, an affected user can unregister the mswrd632 converter by editing the registry as follows:
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Text Converters\Import\MSWord6.wpc
On the Edit menu, click Delete.
Click Yes.
Exit Registry Editor.
NOTE: For x64 systems above path is slightly changed:
HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\ CurrentVersion\Applets\Wordpad
This change will effectively unregister the converter and disable it for third-party applications and for Microsoft Office. Microsoft Office will use its own text converters to open these kinds of files.
You can also fix this issue with applying the registry fix, but that is a less secure way according to Microsoft, as this fix actually creates 'AllowConversion' key in the new 'Wordpad' subfolder. (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Applets\Wordpad)
Download REG fix
There is another way to solve this issue by copying the MSWrd632.wpc file from another computer that doesn't have this issue. Make sure that this file comes from a trusted source on your network. This file can be found on the following path:
C:\Program Files\Common Files\Microsoft Shared\TextConv
OR DO THIS
Go to Tools > Options > General (Tab) in Word 2003
And check "Confirm Conversion at Open"
When you next try to open the document it will prompt you with a list to convert from. Choose Word 2007 and your document will open.
Have in mind that you will have to unregister mswrd632 first, which is noted above, before you make this changes.
NOTE: If none of this works, please check that your file is not corrupted, or that you or someone else didn't add X at the end of .doc extension or vise versa. This WILL NOT work! You have to convert the document using Office 2007 or 2010.
Dec 06, 2010 | Microsoft Computers & Internet
How do i put audio books on my philips SA32xx? what kind of file does it need to be?
File? MP3 is standard. I myself have changed a few audio books as well as radio shows (War of the Worlds by Orson Wells) to MP3 format for my player, and have had perfect results.
Get yourself a decent FREE audio converter2_bing.gif from http://www.koyotesoft.com/indexEn.html
It's user-friendly. Just put your audio book (disc) into a drive, use the free audio converter to "rip" file(s) into a folder (while changing the format), and wait for it to finish.
TIP:
Set it to save "output files" as MP3 at 128-kbs, in whatever folder you choose... this creates a sound and rate of playback that is equal in composition to a store-bought CD. Also, remember to create a seperate folder (or sub-folder) for each project. This keeps files you want saved on your pc orderly.
Place the file(s) onto your player in the manner suggested by it's manufacturer (usually drag & drop). Que it up on the playlist and enjoy!
Jan 31, 2010 | Philips GoGear SA3245/37 Digital Media...
Can a PDF be created from an Excel document? And
yes it can.. just download xls to pdf file converter.. it can convert xls, doc files to pdf file. Or you can simply convert it using the internet. just type to any search engine this keyword "xls to pdf convert"
Oct 23, 2009 | Checkmark MultiLedger for Mac/Windows...
"this document cannot be opened by this version ofQx" (17)
As time goes on software applications tend to change enough that an older version produced file is not forward compatible with a new version. For instance some of my MS Office files no longer can be opened by the latestr version of "Word", hence Microsoft issued a plug in that will allow you older "Doc " files to be read by the latest version of "Word", same thing holds tru for FLASH program, every time a new version of FLASH comes out, the older version can not be read by it.
You need a version of QuarkXpress that can read this doc, If you created the original document, the you can go to your version of QuarkXpress to open the document or if possible ask the originator of the document what version they used to create the document.
Sep 21, 2009 | QuarkXPress
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
My self rakesh,using 2007 microsoft word,how to convert the 2007 word format to 2003 format
Convert a document to Office Word 2007 The Word Convert command clears the compatibility options so that the document layout appears as it would if it had been created in Word 2007.
  1. Click the Microsoft Office Button default.aspx?assetid=za100771021033, and then click Convert.
  2. In the Microsoft Office Word dialog box, click OK.
  3. Do one of the following:
    • To replace the original file with a file in the Office Word 2007 file format, click the Microsoft Office Buttondefault.aspx?assetid=za100771021033, and then click Save.
    • To save the original document in its original file format and create another document in the Office Word 2007 file format, click the Microsoft Office Button, click Save As, and then type a new name for the file.
    Note If the original .doc file is saved in a location other than your local drive, Word keeps the original .doc file and creates a new .docx file when you click Convert.
Mar 14, 2009 | Microsoft Windows Vista Ultimate Edition
MS word 2003 files not retreivable from Cruzer 8GB
I would suggest copy the file ot yoru desktop and open it from your desktop.
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
138 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
