Question about RCA HD52W59 HDTV Projection Television
Blurry Background Maybe there is a way to make the picture smaller, will that help with the sharpness of the background? My 12 year old non HD RCA is 10X sharper then this one. Is there something that will help me get the background focused? Thank You Cordia
  • 137 Answers
Not all the Rearprojections have same picture. Some you must watch at angle to get clear picture.
Posted on Dec 24, 2007
Aperture function
The primary function of the aperture is to control the amount of light passing through the lens. The more light passes through the lens, the less time is required for the proper exposure. A faster exposure can freeze motion and alleviate camera motion, while a longer exposure can allow the subject to blur, conveying a sense of motion.
The aperture also affects the depth of field. A wider aperture narrows the depth of field, causing the foreground and background to blur, while a smaller aperture widens the depth of field, putting more of the scene into focus.
It's up to the photographer to decide which effects to show. Usually for a portrait you'd want the subject's face to be sharp and the background to be blurry. For a landscape, you'd generally want everything from the foreground to the background to be sharp.
May 22, 2012 | Canon PowerShot SX120 IS Digital Camera
Everytime i put a picture for the background on the desktop it doesnt come out clear its all fuzzy/blurry anyone know what's happenin?
It's because your resolution(size) of your desktop is larger than the resolution(size) of the picture. If for example you are running a resolution of 1280x1024 then a picture with the dimentions of 1280x1024 would fit perfectly and not be stretched. See my tip on setting the desktop background here for further details: http://www.fixya.com/support/r6775332-change_desktop_background_image
If you want a smaller image to be centered and not stretched then right click on your desktop and go to Properties. Then click on the Desktop tab. To the middle right there is a heading that says Position. Click the little selection to Center. This will center a smaller image instead of making it all blurry and stretched.
May 27, 2011 | HP w1907 LCD Monitor
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made...
this could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
Bakground of the photo is a bit blurry
this is, in most cases, a desired effect (bokeh) which is used to "detach" the subject from the background avoiding the viewer of the picture to be distracted by the background. This technique is widely used in portraits. This effect effect will be more pronounced when the lens is wide open (in your case it should be f/3.5 if I remember well...). To practice you may try the following: set you camera to "A" mode and take one picture of something (it should not be a landscape) using the smallest aperture after this take the same pic using the biggest aperture. With the lower f number you should get a blurry background and with the biggest the backgroud should be in focus!
May 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Fujifilm Finepixs S9000
Yes set your Dail for M for Motion, and if that doesn't work try and set your ISO to 1600, that should eliminate the PROBLEM..
Happy Holidays
Bobby
Dec 08, 2007 | Fuji FinePix S3000 Digital Camera
Olympus FE 190 pictures are blurry
Check any adjustments that have to with resolution. Do they look more pixellated when you look at them on the computer. Or do the pictures look out of focus?
You should check under the Shooting guide #3 (blurring background) to see if this helps you.
If none of the settings (ISO settings, resolution, lighting, image stabilization mode) help you, contact HP next.
This camera, if I recall correctly, is a fairly basic camera. I would contact HP and see what they can do for you. Since the camera is close to the warranty period of one year, they should cover it under warranty.
Mike
Nov 12, 2007 | Olympus FE-170 Digital Camera
Canon sd 550 (and sd 200) shutter speed
If you check out a review site such as www.steves digi cams. com or even the Canon site to check out the spec of the camera to discover what shutter speeds are available. When shooting fast moving subjects try panning the camera on the object as you press the release this will[to a degree] keep the primary image sharp[ish] whilst blurring the background
Feb 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
46in rca tv
There is a good possibility your tv has a bad picture tube,the fact that is blurry and the age point to that conclusion,you should invest in a new television and prevent the waste of money on this one.
Sep 26, 2006 | RCA F27628 27" TV
RCA HD52W59 HDTV Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
