Question about Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
  • 677 Answers
Are you using Generic Cartridges? Pls See Below
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epsonprinter prints blank pages, have changed and - 2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Posted on Nov 12, 2009
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
My printer keeps printing blank pages. I have cleaned the heads, re-started the printer, restarted the computer, checked all the cables and the problem persists.
You may need to purchase new ink cartridges and install new ink cartridges. take in the old ones into your computer store to make sure you get ink cartridges that will work in your make and model of printer.
If however you have already installed new cartridges then you will want to make sure that the plastic sticker that is some-times placed over the ink cartridge's contacts is removed.
Usually one will need to perform several deep clean cycles to get the ink to saturate the system and print well. Print test pages as you go.
Take care!
damnor01
Jul 19, 2011 | HP Officejet 6500 Wireless All-in-One...
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Will not print annymore
Thomas You need to get yourself a pint bottle or even two pints of ink solvent and a syringe and spray it into the print heads where you removed the ink cartridges and let it set about two hours. don't be conservative with the solvent. Please read the manual for your printer and after you run the printer through several cycles you will see the differences put the old cartridges in the trash and install new cartridges. this can be prevented if you run the printer through its self test and run clean print head cycles.
NOTE: put paper towels in the bottom of the printer so as to not make to big a mess
May 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer "works" but page is blank, no printing. Words are not going from computer to printer. Epson C86. Ink cartridge is new. This happened after I cleared a paper jam.
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Feb 25, 2009 | Epson Stylus C86 InkJet Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Communicates with XP-PC, makes all the moves and sounds- nothing prints
Hi, Hope this helps
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
228 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
