Question about Canon Speedlite 550EX TTL Flash
When I turn on the flash it makes a brief rattling sound. Is fully functional otherwise, but is something going to fail?
The flash adjusts itself with a mechanical zoom lens. What you hear is the lens cycling through its range to "zero" itself.
Posted on Dec 27, 2009
  • 61 Answers
Idk, but im pretty sure its supposed to do dat
Posted on Oct 14, 2009
  • limabeanld Oct 14, 2009
    idk, but im pretty sure its supposed to do dat
Rattling sound when car is in drive
Sounds like an exhaust pipe is loose. Check the exhaust pipe hangers. They are the rubber rings that hold the pipes in place. One of them may have broken or come loose. Also, have you run over something recently that may have been the exhaust? Good Luck
Mar 02, 2014 | Pontiac Grand Am Cars & Trucks
My 1998 sebring 6cyl makes a metal on metal noise on the side of my engine by the belts i tried greaseing all the pullys and i used belt noise sparay but it becomes lower and then it becomes higher ???...
sounds to me from the brief description like you have either a water pump rattling, or a timing chain coming slack. Is the noise coming from the alternator? Never grease pulleys, ever. also the stop squeak spray is bad for your belts. Don't know why they even sell it. If you listen carefully you may be able to pin point the rattle. Is this a tick tick tick, or a rattle rattle rattle? Does sound like a water pump rattle or timing chain slap though. Hope this helps
Jan 14, 2013 | Cars & Trucks
My 2004 Prius has a rattling metallic sound on acceleration. It is coming from the top of the engine on the passenger side. Does anyone know what this can be?
Does the car make this sound when the car has just been turned off and engine is still hot? Lightly push the car back and forth while it's in park. Does it still make that sound?
Sep 23, 2012 | Cars & Trucks
Subaru Rattle on driver side
have the front suspension checked out
most likely a failed suspension arm rubber has failed
check fro failed engine mounts
Apr 27, 2017 | 1998 Subaru Legacy
When I power the Dell AS500 Monitor on, it flashes for a brief second then goes blank but the power switch keeps blinking. The monitor does not function but I do get sound
Check and see if you see a faint image in the back. If you see it, then the backlight has failed. If you cannot see any image, then the power supply on the monitor has failed. You should contact Dell to see if the monitor is covered under warranty in either case as you have a faulty monitor.
Jul 06, 2011 | Dell Computers & Internet
I have Logik MI1006 and it will not play a sound
Please check charger, propoblly light on charger is flashing to. If yes you have to replace charger on new one or fix the existing. ( leroyek69 )
Oct 31, 2009 | Logitech Audio Players & Recorders
M/N GLMV168KS4 - makes a rattling noise when heating food, but otherwise heats properly. All other functions are working. Any ideas of the problem?
It can be a sign of dying magnetron and possible damage to the microwaves chute. If the chute is damaged then the microwave is not repairable. Check the manufacturer warranty on the magnetron.
The failing transformer will cause a deep "growling" noise; the failure of the magnetron will sound more like a sizzle.
Sep 02, 2009 | Maytag Appliances Over-the-Range Microwave...
LG LCD won't fully power up, randomly powers down
i have sae problem, same model . fustrating . i paid over 2,000 for mine.....
Jun 16, 2009 | LG 47LB5D Television
Auto flash not working right
This is actually a repair issue with the flash charging indicator switch. It needs to be replaced as it has failed. You can call Olympus Customer Service to discuss their repair policy and preocedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Feb 17, 2009 | Olympus Camedia Stylus 300 Digital Camera
Canon 20d flash
push the flash into its resting place with a little pressure, turn unit over, take an image requiring flash while pushing on the flash and then quickly release the flash.
something is likely broken and may clear out when camera in alternate position.
otherwise, off to service. don't force it.
good luck
mark
Dec 01, 2007 | Canon EOS 20Da Digital Camera
Canon Speedlite 550EX TTL Flash Logo
156 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
