Monitor type Flatron W1852TQ; video board GeForce 6200 plug & play monitor. When pressing Source button I get a black screen, no digital image or menu to select it. How cna I solve that problem?
5 Suggested Answers
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
  • 17 Answers
SOURCE: Installed new video card, GeForce 6200, but my
Open up your tower and take the little flat battery out for ten minutes put it back in and power up your pc and this should put your monitor back to how it was.
Posted on May 07, 2009
ginko
  • 19396 Answers
SOURCE: LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 4 Answers
SOURCE: How to unlock menu in lenovo LCD monitor
Hi :)
I had the same problem and i found the solution .....
Press and hold the menu button on your monitor for 10-15 sec .
Now ..... have fun :)
Rate if was helpful :)
Posted on Aug 13, 2010
I have a new geforce 6200 evga hd card and have installed it in a PCI slot after first having disabled my ASUS integrated ATI 3300 video through the device manager before powering down and installing the...
I am presuming that the mainboard is an Asus model with integrated VGA.
In order to perform the following steps you may have to remove your new VGA board and reconnect your monitor to the mainboard VGA in order to have a display on your monitor.
If your new VGA board is an AGP or PCI express, connecting your monitor to the new VGA board should have been detected and applied the VGA output through the new board. If the new VGA board is a PCI type then go to the new steps to make changes to your CMOS via the BIOS settings.
If not the Asus mainboard may have to have the CMOS setup change through your BIOS settings.
Upon bootup you should be able to hit the delte key and the BIOS screen should come one.
Scroll down to the a view that will show "Onboard Settings" or similar wording.
Select and disable the Asus onboard VGA or video.
If problem still persist, then go to the Assus.Com web site for support on your model Asus mainboard for the maunual, or trouble shooting questions on settings.
Good Luck
Jul 02, 2011 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Why does the monitor not display when the computer is turned on? It comes up with Analogue Powere Saving Mode and then blank again? I have rectified it now after 36hours hassle. Can you tell me what to do...
The only thing that comes to mind is pushing the source button on the monitor, or finding the source option in one of its menus. If it is on analog and is not displaying an image, you may have to switch it to Digital or DVI, depending on what type of cable you're using to plug it into the computer. Though this is usually auto detected by the monitor when the computer is turned on, unfortunately there aren't many options when dealing with a monitor that refuses to post an image.
May 29, 2011 | LG Flatron L1750S 17" LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
thanks
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Monitor goes black after windows boots up
this is probably your screen refresh rate is too high.try booting the computer in vga mode and lower your default screen refresh rate.if it fails try with a older driver. the problem might be due to overheating. try cleaning your cabinet and install a new heatsink and apply new thermal paste on your vram chips.
Mar 21, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Flatron L1953S Goes to power saving mode while playing..
I had the same problem with my LG Flatron (not the same model as your one). I fixed it by connecting both the digital and analogue cables from the pc. Presumably, the problem occurs because the monitor is not receiving a digital signal.
Mar 18, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Lg w2242t lcd screen is one week old and goes black occasionally when zooming or changing windows, it plays video perfectly, running dvi connection and latest lg driver, rolled back driver to windows plug...
According to your manual, the recommended resolution for this monitor is 1680 x 1050 @ 60 hz. Is this the display setting you are using? Manual is at http://www.lge.com/products/mobile/cdma_manulist_gcsc.jsp.
You should be able to use the driver supplied by the manufacturer, and it should not cause problems! If you are in the U.S., support contact info is at http://www.lge.com/support/gcscWrite.jsp, and includes phone number. Given that this monitor is new, I would suggest telephoning LG for support, and if it is not resolved sufficiently, returning the monitor. This monitor should run perfectly with the supplied driver, and if not, there is a hardware malfunction or conflict. LG should be able to tell you definitively if there is a way to solve the problem, and if not, suggest that you return and replace it.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
