Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Craftsman 1/2 HP garage door goes all the way down, then back up. The lights do not blink. Checked for obstructions, none. Nothing blocking the sensors. What can I do to fix this?
    President:
  • 3,197 Answers
If the door is hitting the floor and then reversing you need to adjust the 'down limit' which is on the side of the motor unit. Turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
Posted on Oct 08, 2009
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp garage door opener will start to close and after 2-3 seconds it goes back up and there is no obstruction blocking sensors
you may need to adjust limit switches in back of operator.Most of the time with this problem one of the gears inside the operator has stripped out.
Jan 26, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 1/2 HP door opener. When I attempt to open the motor clicks but there is no movement. I have tried reprogramming but the issue continued. The indicator on the back is blinking, the light...
Check your door springs. Could have a broken one. Also remove the cover from the motor unit and check the drive gear. It could be stripped. If the light on the back is blinking randomly that is normal. It can also send a code. See if it blinks a number of times, pauses and then repeats.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door had a stripped gear so I
if the stops are not wrong.
they tell it how far to go up and down.
then I think the safety sensor is misaligned.
make sure the light on one side is pointed at the receiver on the other. maybe it is dirty or blocked.
good luck!
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2 hp chain garage door. The light blinks at the garage; will open the door but the remotes do not work. Can you help?
I have worked on a few garage door operners. Sometimes the solder breaks where the metal maked contact. Could have it checked or may need a replacement from Sears.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
For 1/2 HP belt drive opener: With the belt off, the motor sprocket only turns 1/8 - 1/4 turn each time the door opener button is pressed. Although nothing is obstructing the door or the sensors, the...
If the main light blinks 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. Tweak them a bit if necessary.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears/Craftsman Garage Door won't budge
with the door down, disconnect with the emergency release, see if the motor operates
with no load...if the the track moves you probably have something obstructing the door
ie; a broken spring, door locks, etc ... the chain should be adjusted for just a little
**** mid way down the rail (1/4") if it still doesn't move ... call sears.
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changed gear box in craftsman garage door opener
you did not give enough info. If it closes completely and right away goes up, if bulb blinking. if it is, something on door is blocking safety beam. If light is not blinking, DECREASE down travel.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
172 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
