FixYa.com
Tags:
Sony MDS-E12 Mini Disc Player
SPDIF to RME9652
By Gary10 - usenet poster
I've been using a 9652 (24 ch ADAT optical + SPDIF) for a couple years,
mostly with Nuendo.  Windows based, been through a couple OS changes, now
on XP, never had a problem.  I'm using the ADAT light channels to a Nuendo
8IO, and have the wordclock cables going there, also (two-way).  I just got
a Sony MDS-E12 that I want to use to dump a weekly set of MD's we get for a
radio show.  One of the goals of the MD was the SPDIF I/O it had.  So,
silly me, I run a (da*n expensive) digital cable from the Sony out to the
SPDIF pigtail in on the RME and get - nothing.  Nuendo is unable to open
the device, and (obviously) enabling those channels as inputs shows no
signal.
Has anyone done this?  is it a problem to use both ADAT and SPDIF on these
cards, when they are going to different devices?  Is there some clock
setting I should change when not using the ADAT I/O?  Do I need a two-way
connection between the Sony and the RME?
Thanks,
Greg
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Studio Froombosch" <geenspam@geenspam..nl> wrote in
Thanks - I think I'm down to hardware problems.  I found the contact for
RME's tech support, and they've been really great.  Beyond lots of
suggestions of things to test, he sent a little app to monitor any of the
ports on the card, which gets Nuendo out of the way.  I can send a spdif
signal to anything in the studio (I found the Roland we use for remotes
has spdif) out from the 9652.  I can send a signal into anything *except*
the 9652 (i.e. Roland to Sony MD, Sony MD to Roland, but neither of them
to 9652.  Unless they've set a different differential between input and
output, well, thing sick.  thing broke.  need fix.  :)
Off to the races.  At least analog works.  I like analog.
Thanks,
Greg
www.bryantrecording.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
I'm guessing the cap goes in the center as opposed to the shield?  It's
certainly worth a shot, and cheaper than a new card :).
I tried a loopback test, and that failed, too.  9652's output connected
to its own input.  Their little monitor app saw signal going out, but
nothing coming in.  I'm such an idiot.  I should have done that first.
What makes some RCA cables digital, others analog?  I pulled their
pigtail apart, and saw absolutely nothing special. Monster's digital
cable talks about all the special braiding (snort) they did to justify
the cost of the cable, but the pigtail into the 9652 looks just like any
other RCA cable, with the ends soldered to a couple pins. (Continuity was
fine, BTW).
My favorite part of the Monster cable is the sticker showing signal flow
direction.  After all, if you accidentally reverse the cable,  resistance
will build, heat will be generated, and you could *melt* your entire
studio.  Boy, I sure hope they didn't accidentally put that sticker on
backwards.
Anyway, thanks again for the tip - I'll run down a 10nF cap today and see
if anything explodes.
Greg
Solution #3
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
Correct
 It's
Looks like a dead input.
PDIF = 75 Ohm Coax and analog just one or two wires and shield without
karasterictics for high frequencies
LOL! No this is only where the shield is connected.....
I guess it will not work, because the input is probebly dead.
Regards,
Harrie
www.studiofroombosch.com
Solution #4
Not Rated (0)
Peter1
Rating: 0%, 0 votes
The 10 nf trick helped me to connect my Eventide Eclipse to the motu2408. I
think it could be the same trick probebly or the input is just dead....
Harrie
"Greg Bryant" <bryantgHE @yahoo.com> schreef in bericht
Solution #5
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
There are ways spdif work, there are systemens that use differential
(-2,5/2,5 ) and (0, 5V). It could be that those are incompatible with your
machines. Prob an easy way to try if it is a problem is to use a 10 nF
capacitor in the digital signal line.
Let us know....
Harrie
Solution #6
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
Greg Bryant <bryantgHE @yahoo.com> wrote in
Found the "ASIO Multimedia" driver in Nuendo - yes - that's what I've
been using.  Tried "ASIO 9636/52", with no improvement, and DIGI96 with a
complete failure.
Thanks,
Greg
Solution #7
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
"Romeo Rondeau" <romeospamf @oakwoodrecordingstudio.com> wrote in
Umm, I'm using the most current RME 9652 driver from http://www.rme-
audio.com/english/download/dri­vers.htm, which I believe supports ASIO.
I'm not familiar with "ASIO Multimedia" drivers, so, I suppose they could
be in there, too :).  I have to admit, I never quite understood where
ASIO comes into play.  Are they part of the RME device driver, or are
they a virtual driver that comes with Nuendo (or something else
entirely)?
What shows up in Nuendo (1.6) device list is "VST Multitrack", and from
there I can get to all the RME channels to enable/disable them (which I,
annoyingly, can't do from the RME control panel).
Thanks,
Greg
Solution #8
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
Dan Mills <dmi @spamblock.demon.co.uk> wrote in
I normally have the "Pref Sync Ref" box set to ADAT1, "Clock Mode" set to
Master in the RME settings.  "SPDIF In" is set to Coax.  I changed the
"Pref Sync Ref" to spdif.  If I take the "Clock Mode" off Master, to
either Autosync or Wordclock, I get tons 'o crackles.  Autosync finds a
sync signal on ADAT1 (presumably from the 8IO), but the second little
SPDIF in box always says "no lock".  Could the E12 be not sending a sync?
Bizarre.
In Nuendo, through Device Settings->VST Multitrack->Control Panel, I
enabled both SPDIF In and Out, moved them up the chain so they are just
behind ADAT1, and I can do a sync test on SPDIF Out, but the SPDIF in
sync test just gives me the "can not open device" error.
Again, thanks for any help.
Solution #9
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
Are you using the ASIO 96/52 driver or the ASIO Multimedia driver?
Solution #10
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
You are switching the sync source to SPDIF from external wordclock (or
internal master)? The MD player has no wordclock input so it will have to
be sync master for this to work.
Regards, Dan (who has no problem making this work on a hammerfall lite).
And on the evening of the first day, the lord said.... LX1, Go!
And there was light.
The email address  *IS*  valid, do not remove the spamblock.
Can you Help with these Mini Disc Players problems?
Mini Disc Players
sharp CD-G 10000
No suena,no amplifica nada,el... Answer This...
Mini Disc Players
durabrand hm3817dt alarm
How can I turn off the alarm so... Answer This...
Mini Disc Players
diagram equipo sonido samsung...
no hay audio Answer This...
Eventide Eclipse
Hi, I have an Eventide Eclipse... Answer This...
MDS E12 displays 'Over' and ...
Hi, hope someone can help as I... Answer This...
Repair Service
Find Mini Disc Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
