Question about HP LaserJet 2840 Printer
I am getting an error message on my HP 2840 LaserJet: 50.2 Fuser Error. Where is this fuser I've heard so much about?
  • grwhite6 Oct 08, 2009
    Hi
    Much appreciated.
    Is the fuser located at the rear /bottom of the printer?
    What color are the levers you said need to be pushed in (near the gears)?
    How many of those levers need to be pushed in?
    Thanks.
    Sergeant:
    Champion:
  • 208 Answers
The fuser on your printer is very easy to get to. Look at the back of the printer near the bottom. There are two small levers set to lock position, one on each side. Flip them both to unlock position and pull. That's it! That's the fuser right there.
Posted on Oct 09, 2009
    Novelist:
  • 149 Answers
If your printer is still under warrenty i would just take it in to get it fixed.
if not you may want to take it to a repair store i wouldnt recomend doing this yourself but if you want to .
turn off and disconnect the power cable
look for a device with rotating locks and a handle
rotate the locks to the unlocked possition
grab the fuser handle and pull the fusre from the device
the fuser assembly could be very hot so you may want to wait a bit before pulling it out
check the fuser tabs they should be next to gears its just a little metel tab and needs to be pushed in all the way.
but again if getting this error you should take it to someone because there is also a chance that its a low voltage error as well. and the fuser used to cost $300 not sure what they are now but messing with something that cost that mutch may want to be on the safe side and just take it somewhere.
Posted on Oct 08, 2009
50.2 error message
Internal hardware error.
Try cycling the power.
If it still occurs, power off and remove the power cord. Take the fuser out. Wait 20 minutes.
Reinstall the fuser. Reattach the power cord. Power on and see if error reoccurs.
If it returns, you probably have to replace the fuser.
Feb 25, 2011 | HP LaserJet 2840 Printer
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
50.3 fuser error
You need to replace the fuser, a consumable item.
Jun 17, 2009 | HP LaserJet 2840 All-In-One Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
50.2 Fuser Error in HP Laserjet 2840
Printer connected straight to wallsocket,?check the fuser, remove it check for damages, and put it back, if error persist buy a new fuser.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
When you print it cimes on 50.1 fuser error and won't print
Your fuser lamp is not coming on. Reseat the fuser. If that does not help, your fuser will need to be replaced.
Mar 03, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
