Question about Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001)
I forgot password and want to reset to factory default
3 Suggested Answers
SOURCE: i forgot password and want
Its easy but you have to open the unit. Undo the 6 screws holding the base one
Slide out the internals
You will see spot on the board labels SW for switch but no switch soldered to it.
While the power is on, use a wire to short the 2 contacts of the switch that stand out alone. IE. not the 3 together. Hold this short on for about 5 seconds then the led should blink
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual.
Posted on Feb 19, 2011
thanks, I open it and I short 2 contacts [sw1] but after4 shorting its changing the IP only 192.168.1.20 but may be the name and password remain same, bcoz i try to login with defaults user name : admin and password : balck but its fail.
so can u help me to reset it again ?
thanks
Posted on Nov 15, 2011
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Forgot password
or
hope this helps
hope this helps
Jan 14, 2011 | Computers & Internet
Forgot asus RT-G32 router login password. How to change the password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Dec 19, 2010 | ASUS RTG32 Router
I changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
i changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
Jan 11, 2010 | GE Home Security
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Forgot the password of my belkin router
Hold the Reset Button in, (You have to use a Pen Tip) for at least 5 seconds, that should reset router back to factory defaults.
Sep 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Forgot factory default name and password for my Pansonic BL-C131
There's a reset button. It'll clear the user config. There is no default account.
May 10, 2009 | Panasonic BL-C131 Network Camera
Need to reset back to factory default
hello I am using PANASONIC KX-T308 , and forgot its pasword. I want to reset its password back to factory default i.e. 1234. can some one help me ?
May 07, 2009 | Lands Phones
Forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Mar 29, 2008 | Actiontec GT704WG Wireless Router...
Forgot my security password
do *2767*2878# this will reset it back to the default.
Feb 07, 2008 | Cell Phones
Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001) Logo
381 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
