Question about iRiver T50 MP3 Player (IRIVER-T50)
After unsuccessful flashing my player is not determined by the computer.
How can i get adobe flash player to install
Pls clear browser cache.
Also pls check if you have a firewall preventing you to access youtube.
Pls check if you have the same problem with all browsers, e.g. Chrome.
Sep 03, 2014 | Adobe Systems Adobe Flash Player
How to convert a video to mp3?
MP3 is not a video file format.
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Jan 28, 2013 | Audio Players & Recorders
Downloading adobe flash player be come a problem on my computer
When you download and install Flash Player from the Adobe Flash Player Download Center, the download uses the Adobe Download Manager. Instead of using the Adobe Download Manager, you can download and run the Flash Player installer manually.
  1. If you haven't already done so, Uninstall previous versions of Flash Player.
  2. Select the manual installer depending on the browser you use. Select one of the following:
  1. A File Download dialog box appears. Select Save. (If you are using Firefox, select Save File).
  2. Print these instructions and then close all applications.
  3. Open the folder in which you saved the file.
  4. Double-click the file name to run the manual installer.
  5. Select the license agreement and then select Install.
  6. When the installation completes, select Done.
  7. Go to http://www.adobe.com/software/flash/about. If the installation was successful, the page displays the Adobe Flash Player version. For more information, see Determine the Flash Player version you installed, if any.
For more help, please check out: http://kb2.adobe.com/cps/191/tn_19166.html
Jan 23, 2011 | Computers & Internet
I play a game on facebook, and every time I go into the game, a screen says my plugin has crashed. What do I do to fix it?
Depend on your OS. If is Windows IE, some issues has found on this.
Try this :
our version of Windows is either a 32-bit operating system or a 64-bit operating system. A 64-bit operating system can run both 32-bit applications and 64-bit applications.Your browser, such as Internet Explorer, is either a 32-bit application or a 64-bit application. Flash Player works only with a browser that is a 32-bit application. On a 32-bit operating system, your browser is always a 32-bit application. However, on a 64-bit operating system, your browser is either a 32-bit application or a 64-bit application. Make sure you are using a 32-bit browser by following these instructions:
Windows with Internet Explorer
To make sure you are using a 32-bit version of Internet Explorer, follow these steps:
  1. In Internet Explorer's Help menu, select Help > About Internet Explorer. (In some versions of Internet Explorer, select the question mark in the upper right corner to select About Internet Explorer).
  2. If you do not see the words "64-bit Edition" next to the version number, you are running a 32-bit version of Internet Explorer. Continue to Determine the Flash Player version you installed, if any.
  3. If you do see the words "64-bit Edition", go to Flash Player on 64-bit operating systems (TechNote 6b3af6c9) to continue troubleshooting your Flash Player installation.
Windows with other browsers, such as Firefox, Google Chrome, or Opera
No official 64-bit version of these browsers is currently available on 64-bit Windows operating systems. Therefore, unless you are using a test version of a browser (not typical), your browser is a 32-bit application, and therefore, works with Flash Player. Continue to Determine the Flash Player version you installed, if any.
2. Determine the Flash Player version you installed, if any
Before you troubleshoot Flash Player installation, determine the version of Flash Player you have installed, if any. You can see if it is working and whether it is the latest version available for your operating system. Follow these steps:
  1. Go to http://www.adobe.com/software/flash/about. If you have already successfully installed Flash Player, the page displays the Adobe Flash Player version as shown in the following image:
    Note: The version number in this example might be different than the version you have installed.
    If you have not successfully installed Flash Player, you will not see the image.
  1. The same page http://www.adobe.com/software/flash/about has a table that shows the latest Flash Player version available for your operating system (for example, Windows or Macintosh) and your browser (for example, Internet Explorer or Firefox). If the version information shown in step 1 does not match the latest version shown in the table, upgrade to the latest version. To upgrade, continue to Uninstall previous versions of Flash Player.
Note:Internet Explorer uses a different Flash Player than other browsers such as Firefox or Google Chrome. Therefore, if you sometimes use Internet Explorer and sometimes use another browser, you might have installed a different version of Flash Player for Internet Explorer than for other browsers.
3. Uninstall previous versions of Flash Player
Before you install Flash Player for any Windows browser, uninstall all previous Flash Player versions and restart your computer. Follow these steps:
  1. Uninstall all previous Flash Player versions and restart your computer. For Flash Player uninstall instructions, see Uninstall Flash Player (TechNote tn_14157).
  2. Restart your computer after uninstalling.
  3. If you are using Internet Explorer, continue to Verify Internet Explorer security and ActiveX settings. Otherwise, continue to Download and install Adobe Flash Player.
4. Verify Internet Explorer security and ActiveX settings (skip for other browsers)
Make sure that Internet Explorer security default level is set to Medium. This level allows viewing ActiveX controls, such as Flash Player. To set browser security to Medium, perform the following steps:
  1. Open Internet Explorer.
  2. Choose Tools > Internet Options.
  3. Select the Security tab.
  4. Select Trusted Sites zone.
  5. Select the Default Level button. (If the Default Level button is dimmed, continue to the next step).
  6. Move the slider until the security level is Medium.
  7. Select Apply.
  8. Select the Internet zone.
  9. Repeat steps 5 - 7. When done, select OK.
Oct 04, 2010 | Adobe Computers & Internet
Cannot be found in the computer when connected. the usb cable is fine coz the charger works but the computer will not register the usb connection as a flash drive connection under my computer
First try switching to a different driver on your computer... if this is unsuccessful then there may be a problem with the iPod: try holding the "Menu" button and "Middle" button simultaneously until it asks you to connect to iTunes...
This should reset any user changes and allow you to communicate with iTunes...
when you plug in your device and open itunes it will say that you must restore in order to use with iTunes... click OK and continue with that process when you are all done you should be able to sync with iTunes normally :)
Jul 20, 2010 | Apple iPod nano
I can see the top half of the Yahoo mail screen but my email messages do not appear. It says I am signed in???
This problem may be caused by any the following: (you may stop troubleshooting when the problem is solved)
1) Reboot your computer
2) Active scripting and scripting of Java Applets not enabled
In IE click Tools > Internet Options
Click Security Tab, click Internet to select Internet Zone
Click Custom Level
Scroll down to section labeled Scripting
Select Enable for Active Scripting
Scroll down select enable for Scripting of Java Applets
Click OK (Are you sure? Yes)
Click OK on bottom of Internet Options window
Close and relaunch your browser
Try Yahoo! Mail again
3) Update Flash. Yahoo! Mail uses Flash technology. Updating to the current version of Flash can resolve many issues that can occur in Yahoo! Mail:
Install the current version of flash player:
Install Adobe Flash Player
4) Clearing your Internet browser cookies and cache
Click Tools > Internet Options
Click on Delete under Browsing History
Place a check in the Temporary Internet Files and Cookies checkboxes
Click the Delete button
Click the OK button at the bottom of Internet Options
Close and restart your browser.
Try Yahoo! Mail again.
That is as far as I will go for now. There are more things to try, but I would like you to try these solutions first. Let me know if you are unsuccessful.
Dec 28, 2009 | Yahoo Mail
Adobe flash player will not install on my computer. Windows XP! Need help? Any ideas?
How have you determined that the installation was unsuccessful?
Are you simply unable to view flash content? Or have you checked to see what's listed in the active x add-ons in your browser?
In Internet Explorer, for example, go to Tools, Manage Add-ons, and look to see if there is an active -x control from Adobe Systems, enabled or disabled, called Shockwave Flash Object and a version number. If you find this, flash is installed on your system. Make sure it is enabled.
Be aware that you may need to be running your system as a user with administrative rights to install Adobe Flash player.
If that's all in order, please follow these steps to workaround your issue:
  1. Please check to make sure your system meets the requirements for installation of the latest flash player, by going to this link and comparing to your system information. For current Flash Player system requirements, visit http://www.adobe.com/go/flashplayer_sysreq_en/
  2. Follow these steps in order: Troubleshooting flashplayer installation: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_19166&sliceId=1
  3. That should have taken care of it! If not, Download and unzip Install_Flash_Player_10_ActiveX.zip. Extract this executable file to your desktop, close all applications, and run it from there.
  4. To confirm your installation, go here: http://www.macromedia.com/software/flash/about/
If that fixed your issue, great! If not, please report back with details about the error messages you are receiving and give me some details about your system and I'll try to walk you through.
If I've been able to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 18, 2009 | Macromedia Flash MX
Showing mtp and I can,t get in to disable it
first delete it for computer then re install device driver it should install successfully
Feb 07, 2009 | RCA OPAL M4001 MP3 Player
MW3337 MP3 Digital Player
u hav to get windows media player 10 or 11 then when ur on that go to sync put the songs u want in the list o the side
u hav to hook ur mp3 player up to the commputer first then the sync button shuld be able to be press after u press it let the songs get downloaded
Feb 14, 2008 | GPX MW3337G
Voice Recorder
It could very well be related to Vista - go ahead and upgrade the firmware on this player from the Sandisk website
Feb 08, 2008 | SanDisk Sansa c240 MP3 Player
iRiver T50 MP3 Player (IRIVER-T50) Logo
19 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
