Question about CDA Washing Machines
On my cda washing machine, during a cycle the machine bleeps a few times and the screen is displaying E 60 or E 6 (cant remember exactly) iv tried putting machine on again and moving it to spin but it keeps doing it and just stops, with all the water still in it.
    Brigadier General:
  • 3,614 Answers
Hi there, E60 is a problem with this washing machine and it refers to a blocked inlet valve not filling in within correct time or pump blocked or not draining in correct time. hold the drain hose into a bucket and see if the water comes out with force.if it doesn't then you need to check for blockages within the water system pipework. Hope this helps
Posted on Oct 08, 2009
Fault 49
machine needs a new motor controller. can't remember what the code is exactly, but I have seen it a few times, generally replacing motor cont works. I htink it can be a motor problem too, test winding with a multimeter to make sure they are equivalent.
Nov 29, 2013 | Fisher and Paykel Washing Machines
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
Beko WMI 71641 washer bleeping
If the cycle seems to work as in the said sequence then there is a fault in the output to the beeper. Also condensation of moisture can result in such erratic symptoms and so if the board is removed and cleaned dry it can confirm the case. Also switch ON the machine overnight and see if the fault changes.
Jan 02, 2013 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Hotpoint Aquarius WD640 Washer Dryer
I had a similar experience.  I had to try a few times - it has to be EXACTLY together and then the magic "doff" shall appear and save the world.
Dec 19, 2007 | Hotpoint Aquarius WD640 Front Load...
CDA CI532 - Water not emptying
depending on exact version either blocked sump hose or blocked filter Regards Advisor
Aug 22, 2007 | CDA CI532 Front Load Washer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top CDA Washing Machines Experts
noel
noel
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
