Question about Canon SmartBase MP360 All-In-One InkJet Printer
Carriage is locked to the right. When turned on makes a clicking noise and stays locked right. MP360
  • 117 Answers
When an ink tank becomes empty.
("No ink error" displayed on the
monitor or on the machine LCD, or
short flashing of an ink tank LED)
Posted on Oct 09, 2009
Baby lock emp6 troubleshooting
I have a Bablock EMP 6 embroidery machine. It worked great yesterday, when I turned it on this morning it read an error of X-asis home position error. The carriage moves all the way to the right and clicks a few times. It will not center right. I have never had any problems with it. When it make the clicking noise I turned the machine off. I have tried it a few times.
Oct 14, 2011 | Baby Lock BL1556
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
Cartridge stuck; making a terrible clicking noise. The screen tells me to push Set. Nothing happens.
Print head drive gears are stripped out or pulley that the print head belt attaches to is crushed. The pully sits on the right side above where you put the ink and if you can get the pieces can sometimes be crazy glued back together temporarily, the other is on the right side and if damaged is VERY difficult to fix.
Mar 17, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
The cartridge is locked to the right, once turned on makes a noise and stays there???
More than likely the head is getting jammed past the head stop.
I'd suggest that you check into getting the printer service. If the cost of the repair is prohibitive, then consider replacing the printer.
Don
Jan 29, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
System error L1-00
the L1-00 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
If it seems to be moving freely for a bit and then stop - is it going back to its "home" position (starting point). Remove the main glass and then move the scan carriage by hand (with the copier turned off) .. does the carriage move ok? check for a loose carriage drive wire or debris or something broken. Make sure the carriage locking screw is not holding it. Then turn the copier back on and see if the carriage makes an attempt to move back to its starting point. if everything seems to be moving ok then the problem could ly with the "home position" sensor. It could also possibly be a bad drive motor.
Apr 03, 2009 | Sharp AL-1655CS Copier
Scanner lite carriage won't move
still having same problem seems motor that operates carriage is not working would like to change if i can find one i have model#.do u know anything else i can do?
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
SHARP AL-1641CS
If there is a clicking chances are a gear has gone out. It should be checked out be a technician.
Jul 06, 2008 | Sharp AL-1641CS Laser Digital Copier
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
