Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
While cutting the grass, which was much higher than normal due to all the rain we've had, the tractor quit moving. Will not go forward or back. any help appreciated.
  • 472 Answers
SOUNDS LIKE THE DRIVE BELT BROKE OR SLIPED OFF YOU MAY NEED TO TAKE THAT TO A SHOP IF NEED ME TO TELL WERE TO TAKEIT LET ME KNOW
Posted on Oct 08, 2009
Testimonial: "Sounds like that's not something easily fixed at home. If you can suggest a shop I'd appreciate it. Thanks for your help."
  • mickey813
    mickey813 Oct 09, 2009
    IM NOT SURE WERE YOU LIVE YOU CAN CALL THIS SHOP 918-728-1822 HES IN TULSA OK
Tractor starts, but when you shift it into gear, rather it is reverse or forward. It quits...Please help me.
check the grass box safety switch if the box is missing, many machines will activate an auto cut off for safety reasons.
Aug 14, 2015 | Garden
While i was cutting my grass my tractor istop and backed up to cut some grass that i had missed i then put it to forward gear then my mower did`nt go forward. i removed my mowing deck and checked my belts...
sounds like you might either have the wrong size belt or its not routed correctly. if you provide the model number i can show you diagram and part number (size) of belt.
Jul 08, 2014 | Craftsman Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Grinding noise underneath at the back of tractor while realizing clutch petal trying to move forward or backwards then noise stops while tractor picks speed
No it was a bad clutch pad and the slowing up and down was the clutch pad grabbing at certain spots that still had material and the noise was the clutch scratching as it slipped around the clutch plate and them greasing it could have started a fire from the friction of the plate and pad making contact.
Jan 30, 2013 | Garden
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
67 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
