Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Heater leaks water on lower left side (side where gas attaches) towards rear. Do not want to take totally apart to get to leak. Side does not appear to come off.
    President:
  • Jandy Master
  • 1,378 Answers
The heater sides do come off. Your heat exchanger will be what is leaking. Some people (I have never tried) have had them welded at a local radiator shops with some sucess though it is likely the heat exchanger will have several thin areas likely to fail in the near future if you have a leak now.
New heat exchangers are expensive. If you would like a quote, contact us with your heater model and serial number at www.arrowpools.net.
The longer you leave it leaking, the more likely you are to damage other parts down in the bottom of the heater so it is not something you should let sit. If you are going to go without it for a while, close the water off if you have a bypass. Otherwise, consider having the plumbing re-arranged to bypass the heater.
Posted on Oct 08, 2009
  • 4 Answers
Last winter we had a couple of hard freezes here the ice cracked my return manifold. It is interesting it did not damage my heat exchanger, but it did not. Go in from the top. I replaced my return manifold. Not an easy job, but doable. The intake and return are either cast iron or bronze. Mine was cast iron and I replaced it with cast iron. Use the instructions in your manual tiled Reversible Water Connections (mine is 5.4). It's a "how to" in removing your heat exchanger and manifold. Follow the directions very carefully and don't rush yourself. Get some help lifting the heat exchanger/manifold unit out of the heater. It's heavy.....
Posted on May 30, 2014
Our 2004 Isuzu Rodeo has developed a coolant leak. The leak appears to be around or above a little panel or plate immediately behind the oil pan? Cannot find any other source. What is inside the littl
You will have to clarify behind the oil pan. Front of engine towards fan. Rear of engine transmission side. Or above the pan towards engine side. If there is coolant leaking from behind the engine (between the engine and trans) and is not running down from above eg head gasket or hose connection, chances are good that there is a frost plug leaking on the rear of the block.
Dec 28, 2014 | 2004 Isuzu Rodeo
What should I do about a small leak on the side of my water heater?
What is the warranty on this tank?
Warranties covered failed tank.
Does the tank wall have a leak?
If the tank is leaking on top around inlet pipes, or leak is coming out of weld around TP valve, then water heater must be replaced.
Copy following link for troubleshooting and method for prolonging life of water heater by turning off heater except to make batches of hot water.
http://waterheatertimer.org/Leaking-water-heater.html
You can buy water heater at local box store. $350 for gas and $230 for electric, then get store coupon or offer 10% less than sticker price.
Electric water heater is simple to replace.
Gas water heater takes more steps, but how-to step-by-step appears on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 15, 2012 | Water Heaters
Small steady water leak from the left rear side of the 1600CC engine, and this was after a new 'Head' was installed because of a broken 'timing belt'. Car is a 2000 Daewoo Lanos Coupe. All the hoses...
Might possibly be a leaking heater core or a freeze plug on the side of the engine. A small leak might be patched up with some radiator sealer but I would show the leak to the mechanic who repaired the cylinder head first. Hopefully he missed something minor and solve your problem with ease.
Mar 19, 2011 | Daewoo Lanos Cars & Trucks
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
I have a 96 jeep grand cherokee straight 6 with 102000 miles i just found what appears to be water leaking inside the cabin under the passanger side seat and rear left side.
The drain for the water coming from the ac is clogged. Clean it up. It's easier to do that from underneath the car - the drain is located on the firewall.
Aug 20, 2010 | 1995 Jeep Grand Cherokee
Water leak right side kickpanel when it rains water runs down right side kick panel runs through door tray.
check seals around the door and the body where door closes, also check where windshield ends and firewall starts, could be small leak around any hoses or lines that go thru firewall, such as heater hoses and screw holes where parts are attached
Feb 12, 2010 | 2001 Ford F350 Super Duty SuperCab
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Ice maker is leaking water into the ice container making a block of ice . leak seems to be in the front of the mold and heater assembly thanks for your help in advance
make sure your fridge is level. if water just keeps flowing, there may be an obstruction in the solenoid valve that lets the water flow or stops it. it's in the rear of the fridge where the water line attaches. usually blue or white plastic on a brass mount. you'd need to shut the water off, let it depressurize, disconnect the pipe (some water will come out), replace that valve, or take it apart to clean it.
Jul 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Leaking anifreeze from the passenger side of the engine
It is more likely a leaking intake manifold gasket. This is a common problem, they are made of plastic.
May 19, 2009 | 1996 Chevrolet Blazer
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
482 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
