Question about Garden
Mower will not cut But blades are rotating Bolens Tractor Model 3212H Mower attachment 31036S
  • 279 Answers
If the blades are turning, they may have been put on backward. The belt may have been routed so the blades turn backward. Check both things. Good luck...Lee
Posted on Oct 08, 2009
  • 472 Answers
SOUNDS LIKE YOU HAVE A SPRING OFF ON DEK
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Bolens 13ac762f
if blades are turning mower is cutting better to go forwards though
Sep 11, 2013 | Mtd Garden
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
Aug 08, 2013 | Mtd Garden
Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftman 20 1/2 with 42 inch cut deck is leaning more to the front how do you adjust
If you look at the front of the mower there are two rods that attach to the front of the tractor frame. On these rods there are 3/4 nuts that are the mower rake adjustment.First start by positioning one of the blades to a front/rear orientation. <easure the height of the blade from floor at the front part of blade and then the rear.The front measurement should be a maximum of 1/4 inch lower than the rear. Loosen up the lock-nuts on the adjusting rods and turn the nuts clockwise,this will pull the front of the mower deck up.
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
