Question about Bunn NHB Coffee Maker
Water doesn't get hot enough. Can the heating elements be replaced?
  • 11,896 Answers
You may be able to get the elements from repairclinic.com or shopjimmy.com or partstore.com
Posted on Oct 08, 2009
    President:
  • 1,187 Answers
Yes, they can be replaced; however, the element is not available to the public due to BUNN and UL requirements.
BUNN service: 1-800-352-2866
http://www.bunnomatic.com/RETAIL/service/faq.html#faq9
2 Suggested Answers
  • 35 Answers
SOURCE: Does no heat water hot enough
Thermostat adjustment is behind front panel (behind brew basket) on the left-hand side (usually) Work it up gradually otherwise you may risk boil over.
Posted on Sep 09, 2010
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Oct 07, 2012 | Rheem Tankless Hot Water Heater...
I don't think the water is getting as hot as it used to in my Ariston dishwasher. Our hot water heater is set high enough, but when I tried one of the dishwasher cleaners, the plug did not disolve as...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2011 | Ariston Technologies Dishwashers
Does the hotpoint model 9534 have a heating element in it to heat up the water if the temperature of the incoming hot water is not high enough for the set wash? Because when it only has cold water going...
yes it has an element. first thing is to make sure you dont have the "econmy" button selected as if you do this causes the machine to skip the heating stage.
if not its an element you need part number 1601318.
remove the front facia and panel and you will find the element in the front of the drum
Jul 11, 2011 | Washing Machines
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
Water not hot enough. Supply water is plenty hot but washing water is not hot.
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 12, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
I recenty purchased and installed a Whirlpool electric water heater model #E2F40RD045V, when the lady of the house wants to take a shower the hot water doesnt stay hot the whole time. The water heater is a...
Sounds like one of your heating elements is not heating properly.
Check to make sure you are getting power to both of the heating coils, you can check that by removing the two covers over the heating elements and checking with an electric ohm/volt meter for power to the elements. If you have power going to both elements then you will need to check the elements themselves.
Unplug the water heater and then check the two heating coils to make sure they have continuity across the two terminals. You probably will find only one is working, replace it with a new element and enjoy all the hot water you can use.
This is a FREE answer, Please rate me
Dec 05, 2010 | Home
Keurig coffee maker is on, lights lit, machine said it is brewing but no water is coming out
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Feb 03, 2010 | Keurig Special Edition B60 Coffee Maker
No hot water
under the handle of the faucet reached by removing the covering cap and single screw is a plastic geared device which limits the travel of the handle to the hot side carefully reorient so handle will turn a little farther and reinstall handle screw and cap
Jul 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
HEATING ELEMENT IS RURNED OUT
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Jan 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
385 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
