Question about GIMP GNU Image Manipulation Program
I have a B/W map in GIMP. Kinko require a pdf
I have a 4 ft square B/W composite map in GIMP. Kinko requires a pdf format but I cant convert to this. Advice?
  • bcampbell978 Oct 15, 2009
    sounds promising-will follow up
  • 17,970 Answers
In GIMP, you can import and open files in PDF format, but not necessarily save them to the same PDF.
I suggest "print" the original file in PDF format, so you can use "PDF Creator" (free software) Install like a new printer and when you settting the print optionsfor your document, select "PDF Printer", so, this way you obtain a PDF file from you GIMP image.
I hope help you with this. Good luck.
Posted on Oct 13, 2009
1904 sq feet how do I convert this to linear feet for roofing
I have done tons of roofing and we always use square feet .length X width= sq ft .like 50 ft long by16 =800 then double to get both sides of roof is 1600 sq ft
Feb 12, 2015 | Cars & Trucks
Tip
PDF Converter
PDF Download converts the page all while retaining the page layout, fonts, images and hyperlinks on the page. Its support for HTML, XHTML and CSS-based pages ensures the creation of high-quality PDF files, which are ideal for archiving, printing, sharing and emailing like <a href="http://www.anypdftools.com/pdf-converter-for-mac.html">PDF converter Mac</a>. <br /> <b>1. Easy PDF</b> <br />This Converter is used to convert from PDF file to Doc file. It is independent application software that does not require the MS Word or the Acrobat Reader. This program allows you to convert PDF file into Word document with a high speed. You can convert batches of PDFs to Doc format at one time. It has user friendly interface that makes it easy for use. <br />Easy PDF has some salient features as follows: <br />a. It compresses the pdf file as per your requirement without making changes in content and layout. <br />b. You can either add or delete text or images from the resultant Word document. <br />c. It works well on all the platforms like Win98, Win 2000, Win XP and Windows 7. <br /> <b>2. ISTS Office PDF Converter</b> <br />This Converter can convert word file, excel sheet and image to PDF and can also create images from your existing PDF file without affecting the privacy and security of PDF files. <br /> <b>3. PDF Converter Elite</b> <br />If you want to get best result with low cost and high speed, then you can opt the PDF Converter Elite. Using this tool, you will able to convert and edit the existing PDF. Not only this, you can even create new PDF from the older one. It is different from others in some aspects like it helps in creating new PDF and edit them as well. You can extract the pictures and text from the PDF files and export to your desired file format like Word document, Excel sheet or Power point presentation. Moreover, you can create compatible PDF files that can be easily viewed. <br /> <b>4. PrimoPDF</b> <br />This Converter by Nitro PDF Software is a freeware and you can download it from the Nitro Pro Website and install in your computer system. With this, you can even create PDFs from any file format which you can use for printing, screening, use in ebook etc. <br /> <b>5. Cute PDF</b> <br />It is also a freeware that can supports both for 64-bit Windows XP ,and 32-bit and 64-bit Windows Vista. <br />
on Jun 23, 2011 | Computers & Internet
Tip
How to convert word files into PDF format?
<p><span>How you can convert your reports or spreadsheets and any word files into Adobe Document Format ie.pdf. Then you should required free and paid software's available to convert your normal files into .pdf.</span><br /> <p><span>For example you have to download "Universal Converter Software" Using this converter you can convert your web pages, emails, books any others important documents into .pdf. </span><br /> <p><b><span>What are the Benefits of .PDF</span></b><br /> <p><span>PDF files are platforms independent format. For example when you are creating your resume in Microsoft word, and you want that your resume look the same on all platforms, whether computer has any other operating system such as Mac, Linux and Microsoft windows. Than PDF is the important way to send your important documents to others in same and secure way.</span><br /> <p><span> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); PDF can not be modified in text or formatting without your requirement. Internet users mostly prefer the .pdf format because they can download it easily in Adobe Reader.</span><br /> <p><span>These are the step to convert word file into PDF. </span><br /> <ul> <li><span>Download the "Universal Converter Software" and install it onto your computer. </span></li> <li><span>Now open any word document which you want to convert and press the File and then click on Print option to open printer dialog box. </span></li> <li><span>Select the "Universal Document Converter" from the printer list and press Properties button to select the "Document into PDF, Color, and Multipage" profile. Then press Ok button to start the converting process into PDF. </span></li> </ul>
on Dec 24, 2010 | Computers & Internet
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
Hi, I notice that GIMP requires the use of a
there is GIMP available for windows.
follow this link:
www.gimp.org/windows/
which will lead to this download:
http://gimp-win.sourceforge.net/stable.html
Mar 30, 2011 | GIMP GNU Image Manipulation Program
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Dec 04, 2010 | CRL Fixed "All Glass Look" Window for Side...
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 12, 2009 | Audio Players & Recorders
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Michael Vincent Cruz
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
