Question about Swisher Finishing Trailmower - 44cutting Width, 11 Hp
Doesn't mow level if traveling very fast. Should I lower the air pressure in the tires?
  • 472 Answers
YOU MAY WANT TO REPLACE THE BLADE OR MAYBE YOUR MOWEING TO FAST
Posted on Oct 08, 2009
Mowing lower on right side than the left
Loosen the adjuster on one side of the deck and level off the deck and retighten. This should be done on top of a solid surface so u get it perfectly parallel to the ground.
Aug 30, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
Is there a thunderbird 1600 steering damper?
Has it always done this ? Have you checked the bearings , tyre condition , fork seals , fork air pressures balanced etc ? Have you changed the make of tyre ? Check the Rear end also as it can transpher ! You can buy any damper and make it fit as long as the travel is enough and make clamps !
Apr 27, 2014 | 2009 Triumph Thunderbird 1600
Proper deck adjustment John Deere L111
FIRST, ensure the tires have the proper pressure within 1 psi.
The deck should be level side to side, measure from the driveway to the bottom lip of the deck with the height selector lever set so the anti gouge wheels suspended in the air. The side to side tolerance is about 1/8" max. Next measure the bottom lip in front and back (center), the front should be 1/8" lower than the rear.
Adjustments are made using the hanger bracket nuts, turn it left and the hanger lowers, turn it right and it raises. Most decks stay adjusted well, it's the tires and loss of pressure that causes poor cutting or wedge shaped rows. Check the air pressure before every cutting, if it's problematic take the tractor (or tires) and have tubes installed with self sealing compound inside such as tire slime.
Mar 11, 2014 | Garden
My 2009 Nightster tire pressure - I'm seeing/hearing/reading different suggestions. I single ride. right now Front tire is 31, rear tire is 40, is this exceptable. Thanks
Yes, this is acceptable. I prefer to set the front tire at 30 and the rear tire at 36 when riding single. It's a matter of ride quality preference. As long as the tires are inflated enough to prevent excessive flexing of the side walls, you are safe. By lowering the air pressure, you get a bit better traction as your tire's "foot print" is a bit larger but it doesn't handle quite as quickly either.
Good Luck
Steve
Jun 09, 2011 | 2011 Harley Davidson XL 1200N Nightster
Steering wheel shakes violently when traveling over 55mph. What is the problem.?
front tires need to be balanced, make sure tires still have enough tread and front end does not have any worn parts such as inner and outer tie rods and upper and lower ball joints. also check and correct tires air pressure.
Aug 08, 2010 | 1992 Subaru Legacy
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mowes unevenly. Blades don't match up.
make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
May 31, 2009 | Husqvarna Garden
Swisher Finishing Trailmower - 44cutting Width, 11 Hp Logo
61 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
