Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Home Center won't open, and it won't scan
I have the ESP 5. It will print and it will copy, but the darn thing will not scan and the Home Center will not open. This is ridiculous. I paid enough money for this joke. I have run the repair option and it did nothing to change it. I just cannot get it to scan. I'm not a happy camper. Karla Hopper
SOURCE: Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Posted on Jan 27, 2008
Thanks. It worked when I ran as administor on the icon properties
Posted on Jul 17, 2008
iDevelop
  • 55 Answers
I'm not sure if you tried this but download the clear utility from kodak here: http://www.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?osXPor98=winXP
You will need to click start, go to control panel, click add/remove programs, uninstall the kodak home center, unhook the printer from computer, then run the clear kodak utility. Try then to reinstall after. I always install the drivers before the software by plugging the printer into the computer and running the hardware wizard in XP and pointing it to the drivers on the cd then I install the software after. If you need more help or clarification let me know. If this helped you please rate, thanks!
Shawn
Posted on Jan 13, 2009
I finally figured out that it was my "Assembly Registration Utility" whatever that is.Reset my computer back to the factory settings and got the printer downloaded which also cured some other problems.Might not do it for u but worked for me,hope this helps u also.The printer is working really great now!
Posted on Jan 28, 2009
  • 60 Answers
SOURCE: KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Posted on Jun 27, 2009
Am I correct in thinking Kodak ESP 3 AIO is not compatible with Windows 7 XP x64? I can print and copy but cannot scan either directly from the button on the printer button or via Kodak Home Center
Hi There,
If you've installed the software at the link below already...
http://support.en.kodak.com/app/answers/list/p/5/session/L3RpbWUvMTMwMTM1NjI3NC9zaWQveldEWnY1cWs%3D%2Fselected%2Ftrue/selected/true#s=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..
then the answer would be yes. If you haven't install the software and see how things go.
Regards,
Selk
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Doesn't print but will scan and print
Are you saying it will scan and copy but not print? Copy is a local process and Scan might be a local process (done by the device) Print requires the computer.
I would suggest you get the latest version of the ESP 5 print driver. Then, delete your present driver. Turn the computer off, disconnect the ESP 5 and turn the computer back on. Run the package you downloaded from Kodak and follow the on screen instructions.
This should fix your problem. If not ... let me know ... we can try other things.
Thanks for your visit and please come again.
Feb 03, 2011 | Kodak ESP 5 Printer
Printer will print but not scan
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center osftware and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Aug 04, 2009 | Kodak ESP 5 Printer
My printer will not print black from a program on my Pc. I can copy or scan and it will print in black.The color is fine.
The problem is with the Program not the Printer. adjust the settings while printing from that program in printing preferences. try to print any microsoft word document.also, Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning.this should solve the issue keep me posted.
Jun 25, 2009 | Kodak ESP 5 Printer
My kodak esp-3 printer is printing with a pink tint to all my pictures. can you help?
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Bandings on Scaned Images.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. perhaps problem with scanner drivers of the printer. Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. all the best.
Jun 13, 2009 | Kodak ESP 5 Printer
Can oper Kodak home center but cant scan or print from it
No you can't print. You need printer icon to operate.
You can try follow steps.
go to device manager ,   expand Universal Serial Bus (USB),  right click on USB Composite Device, Uninstall it. Reboot your computer. You will get a printer icon,
and you can start printing without AIO Home center.
MS
Jun 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 7 doesnt scan or print properly HELP
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. KEEP ME POSTED.
Jun 11, 2009 | Kodak ESP 5 Printer
My Kodak ESP5 won't scan...
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. may be problem with scanner drivers. new software will fix up your issue. Enjoy.
Apr 16, 2009 | Kodak ESP 5 Printer
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
37 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
