Question about Master Heaters 6 AIRBRUSH CAKE DECORATING KIT-24 Food Color-Compressor
The air is flowing back into the color barrell
Cake decorating airbrush:
The air is flowing back into the color barrell causing bubbles and the color spits everywhere. What causes this?
  • 41 Answers
First of all we must know how is works,that is air enters the brush causing a vacuum at the paint hose,where the hose is dip into the paint barrel,so paint will fill the vacuum where it will attend the brush,so if the air mechanism in the brush is glogged air will flow in the paint barell.Solution is to dismentle the brush and clean the air mechinism
Posted on Oct 10, 2009
I can't get my crayola marker airbrush to spray
The video doesn't tell me anything! I must conclude that the tip of the airbrush is not allowing paint to flow. First see if the air pump is working by removing the tip completely. If it is then the tip can be cleaned with the tools in the airbrush kit!
Dec 31, 2012 | Toys
My daughter bought a master airbrush spray tanning system - g70 - with no instruction manual. air is coming out but no tanning solution - any assistance would be greatly appreciated
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
Jan 16, 2011 | Master Heaters Master Airbrush Model G75...
G22 airbrush is blowing air out of the cap and non is comming out of the tip wtf? checked everything, their is air comming out of the nozzil but no paint.. the cap keeps blowing off and the pain getting...
It sounds like you have a dirty tip. It doesn't take much to stop the flow to the tip. You need to take the tip completely apart to give it a proper cleaning. Just soaking it won't do.
Hope this helps but if not let me know and I'll try and trouble shoot further.
Jun 08, 2010 | Master Heaters MASTER AIRBRUSH MODEL G22...
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Airpreasure backs up into bottle , spits out air and paint unevenly.has done this since i bought it new.thanks ron
hi the actual airbrush has either been assembled incorrectly or has a manufactering fault from new as it has done this from new take it back to the shop hope this helps merlinv12
Aug 14, 2009 | Master Heaters MASTER S62 Airbrush Kit...
Does this dental air compressor have a oil pressure safety switch?if so, where is it located? can I find a wiring diagram
Air compressors are designed to operate many different tools. The value of a commercial air compressor is many times greater than the purchase price because of the amount of work a single air compressor can perform. Dental air compressors are some of the most reliable because of the high-quality air they supply and precision tools they operate. As a result, dental air compressors can be adapted for a number of different tasks, including artistic air brush painting
1.Disconnect the air compressor from the dental tool air supply. Pressure and air supply rate-of-flow settings are different for air brush painting than for air delivery for dental tools.
2.Reset the air pressure on the tank to a range between 15 and 20 pounds per square inch (psi). The exact operating pressure for airbrush painting will vary, depending on the application and the type of paint used.
3.Reconnect an air-supply hose and a siphon style airbrush to the compressor.
4.Fill the airbrush's paint vile with lacquer-based paints. Test the air brush and paint performance on a piece of cardboard, or scrap piece of cloth
material before beginning the painting project. Every time the air compressor is connected to airbrush, or a new paint color is loaded into the brush, a short test spray should be performed. After each test adjust the air volume, and the paint flow in the gun to achieve the desired results8_16_2012_1_32_17_am.jpg
Aug 04, 2009 | Air Tools & Compressors
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
Master Heaters 6 AIRBRUSH CAKE DECORATING KIT-24 Food Color-Compressor Logo
199 people viewed this question
Top Master Heaters Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Master Heaters Air Tool and Compressor Expert? Answer questions, earn points and help others
