Question about Cycling
Bike gears my bike has a gear lever on each side of the handle bars. How do you use these
  • 60 Answers
Usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Posted on Oct 08, 2009
Xt125-16 kin road cyclone when you put in gear the headlights go off! any ideas?
is the light switch on the clutch lever side ? poss loose assy on h,bars or wire ! remove lever and check ! P...
Nov 22, 2013 | Motorcycles
I just cant get used to changing gears,why is there two levers, one on each side of the handle bar.I end up with the chain coming off frequently.
Angie, Have patience. It will come to you. There are two levers, because there are two places where the gears change - in the front (by the pedals) and on the back wheel. You might find it easier to just use one lever. Do this--- have someone help you hold the bike so that the back wheel is off the ground. Turn the pedals on the bike and work one shift lever at a time so that you can see which lever is for the front vs. the rear. If you have three gears in the front (the correct name is chain-rings) then leave the front one so that the chain is on the middle chain ring. If there are two, then select the larger one. Now shift the back one (the gears back there are called cogs). You might have 5,6,7 or even 8 cogs back there. Practice shifting the back cogs to see what is happening. If you find that the chain comes off, even when you leave the front on on the middle chain ring, you need an adjustment. Good luck! Al K
Aug 12, 2011 | Shimano Cycling
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
I have an old Avanti Edge Cro-Mo bike. I know the brakes are on the right handle bar but not sure how to upshift and downshift gears.
If this is the road bike model, then most likely the shifter and brake lever are the same. To brake pull back on the lever, to shift move the lever toward the center of the bike.
The Right lever works the REAR gearing. This makes small changes. The bigger lever will shift the gears toward a larger gear and make the cycling easier. The small lever works the opposite.
The Left lever works the FRONT gearing. This makes large changes. The Bigger lever will shift the gears toward a larger gear and makes the cycling harder. The small lever works the opposite.
If you don't have these types of levers, I can give you different instructions but the essentials of big lever/ small lever and Right/ Left are the same.
Nov 25, 2010 | Cycling
How do i raise the handle bar?
behind the handle bars, where it joins to the bike is called a stem. Remove the center allen key bolt that runs down the center tube. Lift the handle bars up an inch and tighten the allen key bolt again. Your handlebars will now be a little higher for you.
Another way is to loosen the clamp bolts that hold the handlebars to the stem. With riser bars, you can twist them in the same spot and this will angle them up a little. You will have to loosen the brake/gear levers and angle them down until they suit you.
If neither of these works you can buy stems which have varying heights and lengths.
Hope this helps, please vote for me.
Jul 11, 2010 | Diamondback Sorrento 26 Men's...
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
My aprilia rs 125 is ok out of gear but when u put it in gear it dies and have 2 rev the crap out of it
Mate I had this problem, it was the compression, had to get new piston and rings. good luck.
May 10, 2010 | 2005 Aprilia RS 125
How do I operate 10 speed road bike?Schwinn La Tour How do I change gears
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Oct 02, 2009 | Cycling
Having problems with gears on my Apollo LSX 1.1 mountain bike
Sounds a lot like cable stretch. Have a local bike shop replace all the cables and do a derailleur adjustment. Costs is usually under $40 complete.
Apr 17, 2009 | RTO Bicycling Complete Guide to Bicycle...
Cycling Logo
154 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
