Question about Toshiba 65HX83 65" Rear Projection HDTV-Ready Television
I have Toshiba 65HX83. and having problem with remote control. Change new battery but seem to doesn't work. only with on/off butten works. But I think on/off butten itself having problem, because doesn't turn on and off just push one time so push few times and it work. Do you think On/off switch make problem with remote control? For example stiky switch makes remote control not function right something like that. LoL
  • 66 Answers
Try to open the remote and clean the printed circuit with alcohol. In most cases there is moisture on the printed circuit and the button can not make contact. If this has no result you should by an other remote.
Posted on Oct 08, 2009
    Scholar:
  • 86 Answers
Lol?Anywho it could be that.What it is though is far from sticky.Buttons have pressure "receptors" on them that pick up pressure.Otherwise the wires might have been frayed or come undone in the remote control.In that case contact a proffesional or buy a new remote.Hope it helped
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
MY TOSHIBA 65HX83 remote will not operate the TV
You may need to get a universal remote and the programming codes in order to operate everything you'd like to on your tv. I'm guessing the remote you have is newer than the TV?
"Toshiba 65HX81 65 in. Rear Projection Television...65HX83 remote "
Sep 24, 2012 | Toshiba 65HX81 65" Rear Projection...
Remote has stopped working
reset the code again.
2) change by the new batteries
3) clean the contacts batteries very well
4) retigh the spring contacts batteries with pliers, for better contacts.
If after you did the step before mentiones.
Open the remote control, clean the KeyPads, with contacts cleaNERS.
tRY AGAIN.
God bless you
Aug 29, 2012 | Televison & Video
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
The remote doesn't work on my toshiba tv zp38
Check the infrared emission from the remote control first. If it is found OK, repalce the infrared sensor inside your tV.
To get more details about how to check the remote control, get into this blog.
'electronicshelponline[dot]blogspot[dot]com
Named 'Electro-Help'
Apr 09, 2012 | Toshiba 32AF42 32" TV
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
2004 toshiba 65hx83 projection tv
How do you know when your light bulb has burned out? I have sound with a black screen
Aug 05, 2008 | Toshiba 55H70 55" Rear Projection...
Wc-fm2 remote not working
Mine does not work any more. I tried a Toshiba replacement but that does not work either. Sometimes it would power up but the menu and channel change did not work nor the volume.How can I determine if it is the TV and not the remote.
Jul 13, 2008 | Toshiba WC-FM2 Remote Control
Toshiba 65HX83 65" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
