Question about Minolta Maxxum 400si 35mm SLR Camera
Trying to use a Phoenix 500mm telephoto lens and the shutter won't release
  • 302 Answers
Some longer Tele lenses extend into the camera and prevent the mirror from moving up on some models with larger mirrors. One solution> get a 1.4 teleconverter It will add some space between camera and lens. Two solution> buy another Maxxum body on Ebay. Some Maxxums can be bought very cheap.
Posted on Oct 17, 2009
Testimonial: "Thanks, it worked already. The trick is hold down the motor knob and the A/V knob while turning on the camera. This puts the camera in a manual mode "
The Bower SLY500PN High-Power 500mm f/8 Telephoto with T-mount attached to my Nikon D5200 shows 'nop lens attched'. What is the problem?
There is no problem. The lens simply does not have the electronics for the camera to detect. You need to use the lens in Manual mode (turn the mode dial to M). You'll have to set both the shutter speed and aperture yourself, without any help from the camera's exposure meter.
You can take a picture, look at it on the back of the camera (preferably with the histogram) and adjust the exposure accordingly. Repeat until you get a good exposure.
Jan 24, 2014 | Bower Sly500pn High-power 500mm F/8...
Taking pictures with x3 telephoto lens
may be there is some problem with your shutter speed and lens
Jun 18, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Installing the Rokinon 500mm/1000mm f/8.0 Mirror Lens for Nikon
This lens does not have the electronics to communicate with the camera. You have to use the camera on the Manual exposure mode (turn the mode dial to M) and set the aperture and shutter speed yourself. You will not get any metering help from the camera's light meter, but you can use the histogram to fine-tune your exposure. You also have to focus the camera manually.
You'll want to use a tripod or other support, as the lens will magnify every bit of camera shake.
Jul 20, 2012 | Rokinon 500mm 1000mm Telephoto Lens Nikon...
Sigma 170-500mm f.5-5.6. fit on nikon d 200 ??? and i wild like to how good is this one 170-500mm
Sigma makes their lenses with a variety of mounts for a variety of cameras. A lens with a Canon mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it is fully compatible with the D200.
If you mean the 150-500mm, you can see a review at
http://www.popphoto.com/gear/2008/12/sigma-150-500mm-f5-63-dg-os-hsm-apo-af
In general, Sigma supertelephoto zooms have a pretty good reputation. However, only YOU can decide whether a particular lens is "good enough" for you.
Aug 04, 2011 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Just got a 500mm f8.0 Telephoto Lens for my Nikon D90. When I connect it according to the instructions I am certain I have mounted the lens properly to my camera, I have a universal T mount to connect to...
The lens lacks the electronics to communicate with the camera. You must switch the camera to Manual exposure mode by turning the mode dial to M. The lens has only aperture, f/8, and so you have to control the exposure by changing the shutter speed and/or ISO. Unfortunately, the D90's light meter will not give you any help here.
You can get a general idea of the exposure by using another lens before mounting the 500mm. From there you can fine-tune the exposure by using the histogram display on the LCD monitor. This is how I do it with my D90 and 500mm lens.
Oct 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
When i attach the rokinon 500mm f8.0 to my sony a-350 i get the following message: "no lens attached. shutter is locked." what do i do?
Set the shutter mode to "M" to control all funtionality of camera. NOTE: The Rokinon 500mm f8.0 don't have control of the f-number but is loked on the lenses, is unique. I hope i'm helpfull. ENJOY your lenses! i have the same!
Nov 16, 2009 | Sigma Zoom Normal-Telephoto 50-500mm...
Nikon d40, t-mount adapter, showing error no lens attached.
You'll need to switch to M (Manual) mode. You won't get any metering through the lens, nor will you get any autofocus.
Jun 11, 2009 | Quantaray 500mm/1000mm Preset Telephoto...
Soligor mirror 500 on Nikon D-80 ????
The D80 is not able to set exposure with non-CPU lenses like your Soligor, so it probably is very far off on the correct exposure. You must operate in Manual mode and choose a shutter speed appropriate for the lighting. Reflex (mirror) lenses have no aperture adjustment, and I'm guessing your Soligor 500mm is probably f/8 like just about every other 500mm reflex. A good starting exposure for a typical sunlit scene would be 4x your ISO setting. For example, at ISO 400 set your shutter speed to 1600.
Mar 08, 2009 | Samyang 500mm f8 Ultra Telephoto Manual...
Vivitar telephoto lense 500mm
Yes and no. If it doesn't come with one, you'll need a T-adapter for Nikon in order to mount the lens (you can get one from Vivitar, as well as from other manufacturers). The lens is not an autofocus lens, so obviously you will have to focus manually. It's also a mirror lens so it has a fixed aperture. It's what Nikon classifies as a non-CPU lens, so you cannot use the D90's exposure meter. You will have to shoot in Manual mode.
Feb 18, 2009 | Vivitar Telephoto 500mm f/8.0 Mirror...
Minolta Maxxum 400si 35mm SLR Camera Logo
113 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
