Question about Hotpoint RGB532 Gas Kitchen Range
My range electrodes keep firing
I cleaned my range top today and when i plugged it back in my electrodes keep firing what happened and how do i stop this? I have a hotpoint rgb532 gas kitchen range and its got sealed burners. another question. Can i open the range top up cuz i cant figure out how? Thank you for any help possible Bryan
  • Chumba77 Dec 24, 2007
    Please help me cuz im not a smart man
  • 290 Answers
If you cleaned it with soap and water or a household cleaning solution, some of it has probably gotten down to one of the switches that control the surface ignitors. Very common problem. Leave it unplugged when you are not using it and they will dry out and return to normal. You can pull the knobs off and try using a hair dryer, it may help a little, but it basicly is just a matter of time.
There are different variations of this model. If you will post the complete model number I can probably tell you how to remove the top, but there usually is little reason to take it off unless something needs repairing.
Thanks/Mike
Posted on Dec 24, 2007
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Kitchenaid kgss907sss neither the broiler nor the oven will heat with fire. the elecricburner does work however but does not heat well enough. i can hear the igniter click once after turning it on but...
For broil burner ignition an oven broiler burner spark electrode is used to ignite the gas. The electrode is a device that sits right next to the broil burner. It functions like a spark plug. As power is applied to it a spark jumps from the spark electrode tip to the to the electrode shield, igniting the gas. If the electrode is broken or worn out the spark may not occur or be intermittent. Visually inspect the electrode assembly for cracks in the porcelain housing or damage to the electrode tip itself. Be aware that a proper ground and the correct polarity of the incoming voltage to the range is necessary for the electrode control to sense the presence of a flame once the burner is ignited.
there is also a spark control module but I don't think that's it usually no spark when bad.
if you need or want parts ck here for your unit.
hope this helps a little
https://www.repairclinic.com/Shop-For-Parts/-x6b677373393037737373/Kgss907sss-Parts
Jan 05, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
Whenever i light the gas top wolf range, the ignighters on other burners keep firing
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
Aug 11, 2011 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Briggs and stratton 24 HP model ELS 725 mower stopped running have power, turns over, does not fire. please explain your answer with instructions for ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN...
A great expedient spark tester can be made from an old spark plug that you know is GOOD.....clip or grind the grounding terminal ( the terminal which goes over the top of the electrode) back until you have a gap of 1/8 to 3/16 of an inch between the terminal and the electrode...Remove both plugs from the machine and attach your new test plug to the plug wire. Ground the plug by placing it on the head or the shroud. Turn the machine over. If you are getting fire you should see a strong blue spark shoot from the electrode to the terminal. If you have no fire then you probably have a bad ignition coil, bad plug wire, or maybe just a bad seat, brake, or PTO safety switch...I'd check these first. Also check your ignition switch in the run position with a test light to be sure it is good....hope this helps... ;-D
Jul 08, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Amana stove top burners click, and gas comes out, but won't ignite. It's a self cleaning ARG7200, about 11 or 12 years old. Oh, and can I lift this top? I'm used to doing that with old pilot-light...
A weak erratic spark from one or more electrode usually indicates a bad spark module. No spark from one of the electrodes while the others work properly usually indicates a bad electrode. Inspect the porcelain of the electrode for cracks, chips or burn marks. If there are any, the electrode should be replaced. If one of the burner knobs is turned to the light position and nothing happens, but all the others function correctly, the spark ignition switch for that one burner is likely bad. The switch can be taken out of the system and checked with an ohmmeter. It should close for continuity at the light position only.
Go here for:
Amana Range/Stove/Oven Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Amana Kitchen Ranges
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter has started sparking below the range top, not at the top of the electrode. I have a 5? year old Kenmore 75508. The one igniter has stopped working. It only sort-a worked for about a year, now its...
your insulation below the electrodes is breaking down and the hi voltage to make the spark at the electrode is grounding out...replace it...no fix
Jul 30, 2009 | Kitchen Ranges
I have a 30" Viking range with a top burner that continues to click and spark after ignition. I understand that this is a sensor issue...........Is this something that the lay person can resolve on their...
If you only have one burner that clicks when in use then what you have to do is clean the sensor ( the proper name is electrode ) at the top where the little medal disk is with something abrasive. Over time the electrode gets a film on it and prevents it from sending a signal back to the spark module to tell it a flame is present. If it continues to click then replace the electrode. Hope this helps
Jan 09, 2009 | Viking VGSC366-6B Gas Kitchen Range
GE profile glass stove top
You got one or more of the burner switches wet. (It usually happens when you wash the knobs and water stays in the holes until you replace it on the shaft) If just water they may work after a day or two. try using a hair dryer, Keep it at least 12 inches away. If oven cleaner or other chemical got inside switches they may need to be replaced. If you can't dry them out. Disconnect the wires from all but one switch at a time and see which one/s need to be replaced. Sometimes the electric part of the switch can be seperated from the gas part and replaced seperately. DO NOT LEAVE THE STOVE PLUGGED IN until you fix this problem. There have been reports of fires started from this electrical problem. You could also burn out the spark ignightor. The fire problems have been mostly with Maytag/Jenn air products but my whirlpool blew a fuse and shot sparks when this happened to me. I just replacet the whole cooktop as my gas valves were one piece units and way to expensive to repair.
Jun 28, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Hotpoint RGB532 Gas Kitchen Range Logo
153 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
