Question about Crosley Lands Phones
I have the Crosley model CR62 in chrome. The
I have the Crosley model CR62 in chrome. The receiver broke in have,and I would like to replace the part, can you help.
IS THERE AN EXPLODED VIEW OF THIS
These actually come apart pretty easy. The screws are in the bottom, under the rubber feet.
If you dropped it and it quit working, it is likely the circuit board broke - that is what happened to mine.
open it up and have a "go" at it, is pretty easy to understand once the bottom is off.
Mar 08, 2015 | Crosley Radio Cr62-bc Kettle Classic Desk...
Have a crosley model cfw7500kr0 that has locked up and broke the belt
the drive rollers need to be replaced. Need to open it up and check.
Apr 19, 2014 | Dryers
Ok so I have a brand new Crosley record player. All I need to do is find a way to hook it up to my dads old 1980s fisher speakers. How would you suggest going about this task?
Since you don't mention the model I'll assume one - CR2401A - and look at the manual as you should be doing.
It has a Line Out. THAT would feed an amplifier or other standard analog audio device and IT might in turn be able to drive dad's old speakers. The Crosley model X probably doesn't support direct speaker attachment.
Aug 18, 2011 | Audio Players & Recorders
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Aug 17, 2011 | Crosley Dryers
My crosley dryer model number cde6000w is running but wont spin so I am trying to get the back off to see if the belt fell off or broke but cant seem to get it off. Can you help me?
just pop the top/lid up with a flat head screwdriver and if you dont see a belt wrapped around the tub then it is broke. if it is there pull up on it to see if it is tight or slipped off!!!
Jul 17, 2011 | Dryers
Float in tank is broke
hello pcor... here is a link to the contact page for crosley. http://www.crosley.com/ContactUsForm.do
contact them and obtain the part directly from them. Joe
Thanks for choosing Fixya!
Feb 10, 2011 | Crosley DCW25-1 Dehumidifier
Turntable will not turn
I should imagine the belt has either slipped off or broke. If you lift up the turntable matt you might see it.
Jun 25, 2010 | Crosley (CR47) Turntable
Phonograph needle
hello try to visit any repair shop and if you dont still find it i have some of them i need to know what model is it saludos
Jan 08, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Need replacement freezer door for model Crosley WCK05W
are u sure thats the right model # ..can't bring nothing up on that model # Did u get it off a tag that said model#?
Sep 27, 2007 | Crosley WCK05W Compact Refrigerator
Lands Phones Logo
20 people viewed this question
Top Crosley Lands Phones Experts
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
