Question about Uniden Radio Communications
I need to find the proper settings for driver &final bias for a washington 8719 cb.
  • 23 Answers
I assume someone has changed the finals or was trying to get more power and adjusted something they shoudln't have?
Without the proper equipment it is not possible to bias the final stage properly. Take it to someone who has a service monitor and the manual.
Posted on Oct 09, 2009
Power and audio mod
I don't recommend ANY changes to the output power more than 4W on AM of a stock CB radio. The output transistors can be run a bit harder, but the likely hood of them dying is much greater. Manufacturers are cheap, they aren't going to put a 20W transistor in when there are much less expensive 5W transistors. If you want more RF power, then you need to change the PA transistor for one with more power handling capability. You should look for one with more gain as well.
If it is a SSB radio that you are trying to "peak", changing the BIAS settings for the driver and PA transistors is not a good thing. The bias level sets the transistors to their optimum setting for linearity. Changing the bias will not increase your output power, but it will stress the transistors. These transistors are not exactly cheap.
I work on lots of radios and the ones where the "Golden Screwdriver" have touched usually cost 2-3 times as much to repair when they die. And they will die.
Sep 09, 2013 | Cobra HH 38 WX ST CB Radio
No transmit on my uniden washington
Would it help to refer this problem directly to Uniden?
Mar 07, 2013 | Radio Communications
My cobra 1000 gtl cb radio keeps blowing finals
Check bias and check your SWR. Also make sure your coax is not excessively leaky, and also check the loading coil inside the antenna to make sure the coil connections have not become all corroded and that their connections are sound.
Jan 15, 2012 | Radio Communications
I have a galaxy 44v that recieves keys up but know watts come out i have put new finals new voltage regulators b754 and the one in front of it changed the 300v redish " dog tic" thats what we...
  • The Galaxy 44 has 1 final and 1 voltage regulator not "finals." I doubt it is putting nothing out although it may look like it on a watt meter. Check VR16 (low power adjustment for the amp) and VR 13 (High power adjustment) for the amp in the radio. That radio has a variable power so make sure the pots were not turned out of whack. Check VR 14 as well. this is your AMC modulation pot adjustment.
  • Test the driver as well as the pre-driver. Check your microphone to make sure the wiring is good and the PTT is functioning.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 07, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
Radio get hot when modulation bought fan seems to be staying cool
Radio most likely needs an Transmit Section alignment or has a modification in it that is causing this overheating condition. Just a guess i would say that final bias or carrier wattage/deadkey is set to high.
Sep 02, 2011 | Connex 3300 240-Channels Base CB Radio
I changed driver final and now the radio is not keying up.Nothing appears to be burnt anywhere.
now let us ask our selves do we have a good transistor? is there proper voltage on the collector? is there proper bias and drive for the new transistor? Are there any shorts or open circuits pertaining to the new transistor?
Hopefully these questions will get you on the right path to fix the problem.
Ray
73 kf4gyp
Dec 28, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
No transmit after blown final was replaced.
I tried to answer this the first time you posted :). If the finals got burned that bad I found that the bias resistor sometimes will get a burned foil and not make good connection. Also 1/10 watt sounds like the driver isn't amplifying from the buffer. Might want to check for burns on the foil all around the final stages, including where the antenna connector mounts to the board. Don't believe the caps are blown but as a last resort.... Its really hard to troubleshoot without the radio on the bench . Good luck.
Tom
Feb 04, 2009 | Magnum Minimag Base CB Radio
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Jan 20, 2008 | Radio Communications
Radio Communications Logo
78 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
