Question about GE 13TVR62 Combo
My tv keeps turning off automatically after a few seconds
    Genius:
  • GE Master
  • 1,550 Answers
Check the motor charge belt on the vcr sistem
Posted on Oct 08, 2009
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
I have a Flat screen LG TV, 26LG3000, I cannot turn the tv off from the remote or the button on the tv itself when I try to do this the tv will go off but then after a few seconds will come back on again....
Its because you tv is set to automatic turn on ! To avoid this ! When you switch off your tv remember to plug it out from the electricity board !
Oct 15, 2013 | Televison & Video
Power board
The replacement power supply could be defective.
Aug 22, 2017 | Toymax Magnavox 37MF337B 37 in. LCD TV
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Screen automatically goes black after a few minutes
Lamp in TV got weak and TV needs new lamp.
Lamp replacement procedure is written in instruction manual and buy should buy Sony original lamp from Sony Accessories Store for your Sony TV.
Apr 30, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Automatically turns off after few seconds
I had a similar problem and I believe the problem is with the high voltage circuit and ccfl transformers. If you know electronics you may be able to find the chips that provide the power input to the CCFL transformer (I had two transformers and 4 FET's). You will also need a micro soldering station and excellent soldering skills to replace the flat packs (SMT). Hope this helps.
Jul 02, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Mar 26, 2006 | Sharp 27C-240 27" TV
GE 13TVR62 Combo Logo
142 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
