Question about Matstone DO-9001 Juicer
Hello, the matstone doesn't work anymore, we can hear a noise but it doesn't turn anymore, thanks for your help,
Makes a rattling noise
most likely the fan attached to the motor for cooling .try looking here http://erepairparts.com/
Apr 13, 2015 | Champion G5NG853S Household Juice...
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
Juicer was working 5 seconds ago. now it won't work at all...does anyone know who fixes these things.
did it get jammed? sometimes that happens when my kids feed the vegetables in way too fast...I open it up, clean out the jam, put it all back together and it works again. also if it is 'full' and won't take anymore produce it will jam too. hope that helps
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
Hello, and thank you for your time. The juicer was given to me 2 months ago and it's brand new. As of today, some how l can not get it to work. l turned the nob to on, but nothing happens. l opened the...
you have to twist the top round so that the switch is pressed in place so the power can be turned on, from new it takes a few times to get it to click in place this is the safety device so it cannot be turned on by mistake.
Aug 04, 2017 | Hamilton Beach Big Mouth Pro 67600 820.27...
Hello. I have lost my crescent tool and cannot get
Wear leather gloves or double rubber gloves. Hold on right on top of the sharp blades and turn it. You can also bend a 1/8 th inch diameter thick wire, galvanized or anything metal and insert both ends on the holes on the blades and turn it. Make sure you don't slip your hands on the sharp blades.
Oct 22, 2009 | Juicers
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
Instruction manual for matstone D0-9001 juicer
Where are you located, I'm in Canada, and can sell one to you.
Just let me know where you are located to calculate the shipping costs. etc.
Call me if you have any questions:
1-866-273-1101
Maurice Morgado
Sep 30, 2007 | Matstone DO-9001 Juicer
Juicer not working...
me too. it was a x-mass gift. got it out of the box and it wont turn on? bummer
Sep 16, 2006 | Black & Decker JE 1500 Juice Extractor
Matstone DO-9001 Juicer Logo
Top Matstone Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Matstone Juicer Expert? Answer questions, earn points and help others
