Washer FTR630ASO Fridgedaire - inside tub is loose and loud
When the washer spins the noise is very loud and the tub inside seems loose. How do I access this tub?
  • christymcnee Oct 08, 2009
    It's level.
    It's definately the tub inside - it is wobbling all over when I rotate it by hand. It also makes a grinding like sound.
We've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Posted on Mar 09, 2010
  • 291 Answers
Before you tear it apart, check to make sure it's level. If the washer isn't on a solid floor and leveled front/back and side/side, it may vibrate excessively.
Posted on Oct 08, 2009
  • San Juan Vet Oct 08, 2009
    Sounds like the bearing. This is one you can do yourself, but it's pretty involved.
    Can't describe here, it's a bit too involved. But here is the best place I've seen to help you do it on your own:
    http://www.applianceaid.com/frigidaire_f...
    Don't tackle it unless you are confident you can do it.
The washer tub is completly loose
BAD THRUST WASHER IN TUB OR MORE LIKELY BAD MOTOR COUPLER, WORSE YET TUB BEARINGS?
Apr 18, 2014 | Frigidaire ATF6000ES Front Load Washer
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
The tub inside of the washing is very loose and bangs very loud when washing especially on yhe spin cycle
heatman101
Oct 13, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a whirlpool duet front loading washer and during the spin cycle it makes a horrible thumping noise. It seems like the drum inside is very loose as well.
you may have a broken shock, remove lower pane with a 1/4 socket or nut driver, once you have done that you should see 4 shocks at each corner of outer tub, if one has come loose or broken it will sound loud when in spin, it should be easy to notice
Sep 20, 2010 | Washing Machines
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suspension plate
The suspension plate should be loose and float between the frame and base. The pin you saw was a shipping pin, they usually are caught in a little plastic cup attached to the base but sometimes fall to the floor, this is normal too. The tub being loose is normal for the top, it is held down by the springs below the tub but nothing on top. By a loud noise, what kind of noise is it? If it is a very loud ratcheting noise when it slows down then the basket drive(spin tube) and block need to be replaced. If it is a growling noise then that is pump and may be normal if the basket is not spinning. If this is the case look very close for an article of clothing caught between the tub and basket.
Apr 19, 2010 | Estate TAWS800JQ Top Load Washer
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
301 people viewed this question
Top Washing Machines Experts
