Question about HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
My HP VS17e 17" mnoitor goes to sleep when not in use as designed but ther is not way to bring the monator out of sleep without restarting the computor at least once.
  • elilbitz May 11, 2010
    My vs17 won't wake either. How can I possible access the control panel if monitor doesn't wake?
    This was caused by a disconnection for a few hours. Upon plugging in again, it does this. It happened afew years ago and there was a simple fix...can anyone tell me what this is..I think something with the key board???
    Scholar:
  • 80 Answers
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Posted on Jan 30, 2008
Hp vs17e silver monitor goes to sleep as soon as it is turned on.. Not connected to computer.
I know this post is old, but for anyone coming from google ill answer it.
Most likely the CrapXon... I mean CapXon capacitors took a dump. Located at 822-824 on the main board. Replace those with some good authentic Rubicon, Nichicon or Panasonic 10V 1000uf caps and this thing should last till the CCFL tubes fail. If you are repairing this yourself, you might want to get a 10uf ceramic cap as well, since the white glue stuff that HP put on these things to keep them intact after a meltdown, might break your 10uf cap's insulation off at location 821.
Aug 23, 2010 | HP Vs17 17" LCD Flat Panel Monitor
When it goes to s;eep and i try to bring it back
you are using pirated latest version. this is a problem of drivers only either download drivers from http://www.vistaheads.com/forums/register.php or use the older version of operating system
Apr 12, 2010 | HP 2009M Monitor
Monitor says it is going to sleep and there is only a black screen.
Monitors go to sleep when there is no computer activity it detected. Also, when your OS is working and somehow you have set a "sleep" time, then the monitor goes to sleep at the appointed time. Just press ENTER or press the POWER BUTTON to bring it back to life without losing your computer work.
Oct 29, 2009 | HP f2105 21" LCD Monitor
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
HP vs17e sleep after 15 sec when turn on. How to fix it working? tron on it sleeps turn on it sleep
Usually it is from power supply ... cheack it with other power supply... or adaptor..
Dec 03, 2008 | Computers & Internet
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor goes into sleep mode directly.
I THINK THE INTERNAL PCB (power control board is bad) avoid problems in the future by simply replacing this monitor with a new one.
A new monitor gives you all new parts and warranty without the riskof the same problem.
when chosing a new monitor please check the rewiews on the one you have chosen via the internet before you buy it to avoid manufacturing or engineering defects resulting in future problems.
Jan 15, 2008 | HP Pavilion F1703 17" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
236 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
