Question about Apple Power Mac G5 Desktop
Stuck dvd tray
My dvd is stuck in the tray (Mac G5). It does not respond to the Eject key / F12 key (tried two different keyboards as well). Also tried inserting straightened paper clip into small hole next to tray with no results.
  • 2,841 Answers
There are many ways to eject a DVD. Try this.
Shut down the computer (complete power off, not restart)
Hold down the left button (Apple mouse?)
Push the power button
Keep holding the mouse button down until it either ejects or the grey pinwheel appears. (It's not an instant process)
Usually, eject/F12 will open the drive up. If that does not work try.
Open terminal and use the command "drutil tray eject"
You can also try command-option O + F and type"eject cd"
If none of this works your drive may be bad or the power cord is loose. You will need to open it up or seek professional service.
Posted on Oct 09, 2009
What key to use to eject a CD on a Logitech using Mac
How to eject disc from Mac using keyboard?
Hold down F12 as you restart the computer until the CD ejects itself. Hold down the left mouse button as you restart the computer until the CD ejects itself.3 Mar 2012
How to Eject a CD From Your Mac Using a PC Keyboard or USB ...
www.iclarified.com/.../how-to-eject-a-cd-from-your-mac-using-a-pc-keyboard-or-usb-... Search for: How to eject disc from Mac using keyboard?
What key to use to eject CD on Logitech using Mac Google Search
Nov 02, 2017 | Logitech Computers & Internet
Cd stuck in mac laptop
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge.
Feb 18, 2013 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
Dvd tray opens
If this is random or constant, check to see if your eject key is stuck on the keyboard.
Nov 04, 2012 | Apple Power Mac G5 Desktop
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
PowerMac G5 doesn't eject
Your DVD wont show on the desktop unless a DVD is inserted. Which means that the DVD is either upside down, or simply isn't recognized by the reader. There should be an eject button on your keyboard. Hold that for 3 to 5 seconds and see if it ejects. If not, look for a tiny hole in the front of your case and insert a paper clip and push in until the DVD ejects. Some Macs have no hole and require a shop to extract the DVD for you. Another trick is to start up the PC while holding down the C key during bootup, which will make the PC try to boot off of the DVD. At which point the DVD should eject as the system asks for a proper boot cd.
Feb 28, 2010 | Apple iMac G5 Desktop
DVD will not eject
To eject a disc.
  1. Use the eject option in the menu bar by selecting open from the drop down menu.
  2. Press the eject or F12 key on the keyboard.
  3. Open the drive face plate and insert the end of a paperclip into the small hole under the drive tray area. This will pop the tray open.
Hope this helps. Don't forget to vote or leave feedback, Thanks.
Feb 23, 2010 | Apple eMac G4 Desktop
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
CDs get stuck in the slot of my mac mini---3 years old.
Ok, let's go through the options in case you have missed one. Command E, Open Finder and click eject button next too it's name, dragging the item to trash, press F12, or hitting eject on the keyboard. If none of those work make sure the drive is not just busy. Sometimes you have to wait a few seconds even after stopping the application. You can use Disk Utility in Applications/Utilities to eject a CD. Open Terminal and type drutil tray eject If that fails, in Terminal type drutil list and then look at the list and find the drive. Tyoe drutil tray eject 1 The 1 should be replace with whatever drive # you found in the list.
Aug 05, 2009 | Apple Mac mini G4 Desktop
DVD reader
Hi I'm sorry you are having trouble,
OK, when was the last time your CD/DVD trey opened properly when instructed by pressing the eject button on your keyboard ?
This (and all other apple computers now) machine does not have a button other than the keyboard eject button to eject or open the trey. The eject button is usually the last key at the top right hand of the keyboard. If you are not using an Apple Keyboard, it does not always work. And, sometimes, that key no longer sends it's request to the Mac... SO,
Have you tried another keyboard ?
Is there a Disk in the reader? Sometimes the disk itself confuses the reader and paralyses it and restarting won't help it even freezes the system....
That is why there is another way to get the CD drive to open or eject a disk that won't come out:
Restart your mac or from an off position, turn on the Mac and VERY QUICKLY press the mouse button ( If you have a mighty mouse, be sure to click the left side of the mouse ) and hold that mouse button down until the disk ejects, depending on how much ram you have, it could take 10 seconds to 70 seconds, be patient...
If the Mac boots without ejecting the disk, then either your mouse or keyboard are not connected directly to the mac, this does not work well through a USB Hub, or the mouse or Keyboard are defective.
Keep trying it with other keyboards or mice until you get that drawer opened.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Apple Power Mac G5 Desktop Logo
291 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
