Question about HTC Control4 AVM-HTC1-B Home Theater Controller - Black System
Lg tv goes blank for about 3 seconds when certain light switches in the house are turned on or off.
Your home is not grounded proper
Posted on Mar 12, 2010
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
LG TV Doesn't Turn Normally
Contact the authorized service centre for LG. The fault sounds like strange.
Gopakumar Gopalan Google
Mar 27, 2014 | LG 42LE5500 42 in. TV
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Lg tv turns off after a few seconds, the screen lights up but doesnt even say no source....
hi i have a lg 42lc46 and it wont turn on from stand by it just goes blank and the red light disappears can yiu help
cheers
mike
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
LG tv
That could be ;the ballast power section to ligth up
the screen. ;look inside the back panel if the neon are light on if not you have a problem whit this circuit
you will need a technician if neon are on , try change the input (video in 1,2 3 and tunner, if all gives any result ;you have to think about a bad ground in video circuit or main chassis y/c board;in a way or another
you may need a good tech ...
hope that give you a idea
have a nice day
Mar 16, 2010 | LG 37LG50 37 in. LCD HDTV
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
LCD TV blanks out when I flick the switch for my room lights
Do you have surge protector installed? If not, you should use one, something like MONSTER CABLE.
Nov 27, 2009 | Televison & Video
Tv turns off after 3 seconds
ok i know your problem. pls check the secondary power supply check all electrolytic capacitors you can use your eyes by scanning budged capacitors. 220microfarad/ 25volts.
Jun 07, 2009 | LG 42LC2D 42 in. LCD HDTV
TV switches off after 3 minutes
You have a bad Fan,if fan stops turning on while tv is trying to come on lamp will not light and tv turns off.
Nov 24, 2008 | LG RU-52SZ51D 52" Rear Projection...
HTC Control4 AVM-HTC1-B Home Theater Controller - Black System Logo
80 people viewed this question
Top HTC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HTC Audio Player and Recorder Expert? Answer questions, earn points and help others
