Question about Technics SUV500 2-Channel Amplifier
No sound i just got an "AV control stereo reciever (SA-EX300)" and when i turn up the volume there is no sound on the speakers (and yes everything is plugged in right ) no matter what i do. even when it is on the right setting there is still no sound. what do i do
  • joyman796 Aug 06, 2008
    where is the fuse on these [ SU-G70 ] its an older unit
    Problem Solver:
  • 12 Answers
What are you tring to amplify? try using a different input.
also try checking all the fuses! llllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll
Posted on Dec 24, 2007
My partner's AV control stereo receiver sa / GX 650 has presented complications can not crank up the volume without alert saying overload or some s***?
turn it off and take a look at each speaker and wires something is wrong even a bad speaker may show this in your amp so before you burn it test all of them
Sep 16, 2015 | Audio Players & Recorders
My technics av control stereo receiver sa-g76 keeps shutting off(overload). can you please advise on how to avoid this situation?
Is there anything on top of the av receiver? Try and run the reciever so that it has enough cooling. B) Allthough overload, there is a possibillity it is causes by speakercables who are shortcircuiting once in a while. Usually somewhere at the back of the reciever or speakers.
Apr 24, 2014 | Audio Players & Recorders
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
Can i hook up my technics sa-g76 to my tv
yes, using the the rca outs of your tv, and they will connect to an input on your reciever that may already be marked for a tv, or cable box
Jul 28, 2013 | Panasonic Technics SA-G76 AV Control...
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Over Load light turns on and then we have no sound
please disconnect each speaker one by one and test it until you find the bad one-start with cable change and then the speaker itself.
Jul 04, 2008 | Technics Audio Players & Recorders
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
Technics SUV500 2-Channel Amplifier Logo
89 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
