Question about Infinity KAPPA692.9I Coaxial Car Speaker
I have 2 infinity kappa speakers in the rear deck of my car. i had a stereo system in the trunk but it didnt really do much except throw more bass in with the music even then it wasnt that much bass. i sold that system and now there is very little music coming form the rear i checked the wiring connection and it seemed fine. do i need another set of speakers?
  • Matthew Spark
    Matthew Spark May 11, 2010
    did you have fairly airtight covers on the back (inside the trunk) side of the infiniti's? if not, the air pressure produced by the speakers in the trunk may have damaged the infinitis
  • 38 Answers
You sold the subs, or sold the infinity kappas? After selling a sub system it is often more than disapointing to go back. It often does sound quiet. You can either deal with it for a couple months until you get used to it, or I'd go with a set of MB Quart to replace your kappas.
Posted on Oct 10, 2009
I have a kicker zx350.4 for door speakers and the amp keeps cutting off once the bass hits hard or i have it aloud , once i put the volume down or bass low it comes back to normal and amp doesnt get hot at...
kappas are 2ohm. You are running that amp at 2ohms stereo on front and rear channels. That is a nice amp, but it is a thirsty one. If you have a sub amp as well, then you are not supplying your amps with enough power. drop down to 0 gauge and see if it heats up anymore. Also, try going high pass if you have subs. If you don't have subs. You need to run 4 gauge and make sure you have a great ground.
Oct 31, 2014 | Car Audio & Video
2008 Hyundia Sonata infinity stereo amp location
I have not yet had a chance to verify, but I read in another forum that it is located under the passenger side rear seat.
Sep 24, 2012 | Infinity kappa one Car Amp
42.1i passenger side rear has power but sound is very quiet and tinny. all 3 other speakers work fine.
It sounds like the woofer part of the speaker is bad, while the tweeter is still good. You are going to have to replace the speaker. Speakers are generally sold in pairs, so it would be best to replace both rear speakers at the same time.
Jul 18, 2012 | Infinity KAPPA 42.1I Car Component System
Need full stereo wiring diagram
Hi there:
2004 Infiniti I35 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Yellow
Car Radio Switched 12v+ Wire: Violet
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/White
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Under the rear deck.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Hope this helps.
Mar 06, 2012 | 2004 Infiniti I35
Back speakers can't handle bass
you need to replace all the speakers in the truck except the front tweeters if you have them. I replaced all four with new infinitys from futureshop. Installed it was near 500 dollars. You need to get 2 ohm to match the infinity deck if yours is infinity. Most other systems are 4 ohm, these are 2 x 2 ohms for 2 and 4 ohm use. the factory's are garbage and use paper cones. The rears have plastic caps holding the tweeters in. On all four the paper was ripped away from the magnet and it caused them to vibrate and shake, once replaced with 180 watt infinitys...great sound.
Jul 06, 2010 | 1997 Jeep Grand Cherokee
I have a 2002 Chevrolet Camaro with the Monsoon stereo system, The front speakers take four wires. The Infinity Kappa 62.7i were the perfect speaker, but they stopped making them. I do not want to put...
one of those wires on your speakers is the common ground for both sets of wires in your camaro, Just take the negative wire from both sets of wires and run it to the single wire on your new speakers. The other 2 are positive from each wire. good luck
May 24, 2010 | Infinity KAPPA 62.9I Car Component System
Finding the right speakers
you should install 2 8 or 10 inch wooffer on the back seat install mid range and tweeter its not very expensive it gonna sound great with that trunk you can do anything you whant 6x9 its sound like crap even the expensive one
Jan 17, 2008 | Competition Crystal COMP 10 - 10"...
Car stereo im trying to build
I guess the question you need to ask yourself then is how much money are you willing to spend? If you are looking for a sound quality system then it WILL cost a lot more than a DB all out BASS system. The system that you have picked out isn't a bad one but as with all systems this in only half the story. You will need to have it installed well to get the best from the speakers that you have chosen too. If you want to have the stealth look in the cabin then it's pretty simple, but you will not get the best sound quality or should I say imaging as the OEM locations usually are no good for this.
I would suggest that even though you keep things looking stealthy in the cabin apply sound deadening to the doors as Asian cars are generally quite tinny unlike German cars. This will make a big difference in terms of overall sound quality & help keep out the road noise so you can hear every little detail of your personalised system.
Dec 25, 2007 | Car Audio & Video
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
Infinity KAPPA692.9I Coaxial Car Speaker Logo
361 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
