Question about Epson Stylus Photo R300 InkJet Printer
General Error Was printing some CD/DVD's and suddenly stopped and says general error. I have sut down the computer, shut down the printer, restarted with the printer CD/DVD tray closed..I have tried everything I can think of...
SOURCE: general error
i have some problum of epson r230 printer general eror please send me this problum solution
Posted on Oct 31, 2008
in my r300 epson printer general error appear . How can i remove or clear this error from my printer lcd
Posted on Apr 27, 2009
  • 511 Answers
SOURCE: epson printer maintenance 230 General error
General error : head carriage error / chip not recognized. Head carriage can't move freely. Just turn off for about 1 hour, turn on again without ink tank. Plug ink tank.
Posted on Jun 13, 2009
  • 511 Answers
SOURCE: epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Posted on Jun 24, 2009
  • 787 Answers
Probably the waste ink tank is full.Try to do this:
First of all download to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Posted on Oct 16, 2009
SOURCE: General error for epson stylus T10
green & red light blinking cant print epson t10
Posted on Dec 07, 2010
0 characters
1 Points
How do I fix my printer?
throw it in bin
check you pc memory also
May 05, 2016 | Printers & Copiers
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Printers & Copiers
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
General error
The general memory error is contributed to a LARGE PRINT JOB that is stored within the systems NVRAM. We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Jan 24, 2011 | Generic Memory Epson T033120 Black...
The sgreen says general error, see your printer documentation for information about clearing the error.......of course I can't find the manual
Everything you need; manuals, drivers and interactive guide can be found here:
Below are two possible soultions for a General Error:
1. When a General error message appears in the display on your printer's control panel, the print head may not be able to move because of some obstruction. Follow these steps:
  1. Turn the printer off.
  2. Open the printer's cover.
  3. Gently remove any jammed paper or other obstructions from the paper path.
  4. Close the cover and turn the printer back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the printer.
2. When a General error message appears in the display on your printer's control panel, the print head may not be able to move back and forth freely.
If your printer's ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps:
Turn off the printer.
  1. Open the printer's cover.
  2. Press the ink cartridge cover to make sure it is completely closed.
  3. Close the cover and turn the printer back on.
Before considering other options you might to try unplugging the printer from the power supply; give it 5 - 10 minutes before plugging back in and restarting.
Hopefully this will help resolve the problem. :)
Dec 09, 2010 | Epson Stylus Photo R300 InkJet Printer
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from
Aug 18, 2009 | HP Printers & Copiers
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
It doesnt print
delete your printer from your computer and reinstall it.
This will reset it. Make sure you have your cd with software and drivers handy or that you can download drivers from your printer company site under support of you device first.
You shouldn't need the drivers but just incase.
After you delete your printer out reboot your computer and reistall your printer. If running windows 2000,xp or Vista it should reistall it when you reboot.
Apr 02, 2008 | Epson Stylus RX580 InkJet Photo Printer
It doesnt print
well..maybe...can you do a test page ok?
Epson Stylus Photo R300 InkJet Printer Logo
29 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
