Question about CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
I need a replacement gas valve as mine siezed and can't turn the gas on my cadac Carri Chef bbq grill
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Posted on Sep 30, 2011
  • grundy8472 Sep 30, 2011
    email me at grundy8472@o2.co.uk if unsure etc, cheers jay
How do I store the BBQ do I have to detach the gas cable every time I put it away?
Unless you are putting it in a place that you can't fit it with the tank attached then there is no reason to detach the cable. Just make sure that the valve on the tank is shut
Oct 28, 2014 | CADAC Safari Chef Portable Grill
Can i convert my cadac safari chef from hp to lp
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Using a cadac burner with a skottel model extension 8304 , with no 24 Jet ( using a LPG 9kg gas Bottle - no Regulator ) flame is good on full ( good Blue Colour ) however on Low Flame keeps going out...
My experience shows me the old steam engine problems.
No gastight connections where they should be.
So not the specified Kilowatts output.
Think of the old fashioned flanges witht the artificial (synthetic) rubber gasket between them. And the flangebolts which held them together, all with the same torque momentum in kilopounds/meter.
Check with good quality leak detection foam and/or use your imagination.
Alternative: look for YouTube High Definition
video 'The Cadac Legend', as of August 15, 2011.
Dutch: ................... Trek in BBQ.
English: ................. Draught in BBQ.
Talkin' about airtight/gastight connections.
Oct 08, 2010 | CADAC Safari Chef Portable Grill
I need an instruction booklet in order to sell a Cadac Carri Chef
go to there homepage and find files and download it disc usually it s an adobe file and burn from there
Aug 10, 2009 | CADAC Grilling
Gas is very slow will not burn hight
You are opening tank valve to fast. Tank valve thinks it is leaking when you open to fast and shuts down. Unhook tank, hook back up, open valve slowly. This should correct problem. Remember to always open valve slowly.
Jun 16, 2009 | CADAC Safari Chef Portable Grill
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Cadac carri chef
Hi Ronaddo, where are you living?
Jun 01, 2008 | CADAC Grilling
CADAC Safari Chef Portable Grill Logo
520 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
