Question about Emerson MW8985W Microwave Oven
What is wattage on Emerson microwave MW8985W - Emerson MW8985W Microwave Oven
  • Emerson Master
  • 9,085 Answers
You can visit Emerson here or get call them at 1-800-898-9020.
Many Emerson microwave owner's manuals are available for free download
here.
Even though yours may not be there, there might be one close enough to help you.
Posted on Oct 11, 2009
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Posted on Aug 28, 2009
marked
  • 6487 Answers
SOURCE: Need Owners Manual for Emerson
You can get the user manual for this unit from this link.
http://www.servicemanuals.net/OwnersManual/EMERSON/MW8985W/pos1/results.aspx
Posted on Aug 17, 2010
Carousel does not rotate
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 08, 2011 | Emerson MW8985W Microwave Oven
What is the wattage?
Hi .. Wattage is a measure of power .. it is the voltage a device opperates at multiplied by the amount of amperage it uses. Sometimes called volt- amps. For an example of this, a 200 watt lamp, on a 120 volt circuit, is using about 1.66 amps. That typical circuit is rated for 15 or 20 amps. The rating is determined by the wire size and the breaker protecting the circuit .. so on my lighting circuit I can install about 8 to 10 of these lights and be safely within the limits of the circuit. For a 1000 watt microwave , on a 20 amp kitchen circuit, this means that the microwave is using about half of the capacity of the circuit. You are charged for your use of electricity by a rate times your usage in kilowatt hours, or how many watts you use, times the hours you are using them.
May 06, 2010 | Emerson MW8985W Microwave Oven
I need to know the wattage on my old 1990's model Quasar Superwave micro/convection oven. Can you help me? Thank you, Gloria
You probably already know, but the wattage is 800. There should be a sticker or plate on the back or underneath the unit with some specs.You can also try calling Sanyo Fisher service for more info at 800-421-5013 Monday - Friday, 7:30AM - 5:00PM PST
Also check http://kitchen.manualsonline.com for a manual. I really hope they can help you.
Mar 29, 2010 | Emerson MW8985W Microwave Oven
I think the fuse blew on my emerson microwave. Can I check myself by removing the rear panel?
Unplug the power. Remove the screws, on the back that secure the outer case and slide it off to the rear. Check near the control panel for a clear glass fuse. If it is bad, make sure to replace it with one that has the same ratings.
Jul 11, 2009 | Emerson MW8985W Microwave Oven
How many watts on my microwave?
Hi
The wattages of your microwave is 800 watts.
Thanks!
Jun 15, 2009 | Emerson MW8985W Microwave Oven
Emerson microwave oven model MW8985W suffix C
Many of the magnetron cooling fans merely press onto the shaft of the motor. If yours is worn out, you would have to replace the fan blades.
May 03, 2009 | Emerson MW8985W Microwave Oven
Wattage for MW8985WD microwave
I still have a orginal lable on my microwave, it is a 800 watt oven.
Jan 13, 2009 | Emerson MW8985W Microwave Oven
Instruction manual
You can download that free here.
Dec 22, 2008 | Emerson MW8985W Microwave Oven
Glass turntable replacement for Emerson MW8985W Microvave.
Check with www.microwaveglasstrays.com or call them toll free 877-894-0035
You'll be loooking for part # 3517203600. Should be about a 10 inch tray
Jul 16, 2008 | Emerson MW8985W Microwave Oven
Emerson MW8985W Microwave Oven Logo
1,055 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
