Question about Kitchen Appliances - Others
My deep fryer pilot goes out all of a sudden. Every thing goes well at first, then when it gets going good, it shuts down and the pilot goes out too.
  • 612 Answers
Pitco's are known for this. Locate the high limit. It under your thermostat and has a red reset button that you can push to reset it. Check the wires that come from it and make sure they do not have a broken place in them. If not, you will need a high limit switch for it. What happens is when the high limit gets weak and instead of turning the gas valve off after the oil gets 410 degrees, it cuts it off at a lower temp. As I stated, it's a common problem with Pitco. You can find the part at www.hfse.com . They carry parts for most all make and model unit. Good luck.
Posted on Oct 18, 2009
How can you tell if the pitco fryer safety switch is bad
The safety switch is operated by extremely high temperatures. If the safety switch is bad, it will not shut off at extremely high temperatures.
Jun 02, 2014 | Imperial IFS40 Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
Pilot light goes out
Two things to check. Make sure you have continuity through the terminals on the high limit. Also make sure you have a good pilot flame and the pilot generator is supplying over 500 millivolts. It's either the high limit or the generator.
Tom
Jul 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Mar 09, 2009 | Vulcan GR35 Deep Fryer
Imperial deep fryer IFS40 pilot lights, turn on gas valve main burners come on run for awhile then everything shuts down main and pilot. You can disconnect the thermostat and the same thing happens, main...
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Feb 18, 2009 | Imperial IFS40 Deep Fryer
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
Lie up deep fryer
Hello. Could be three things, from what you describe, it sounds like your pilot is dirty, and not heating the thermopile enougher, and pilot off to energize the pilot portion of the valve. You could also have a bad thermopile, and no matter how long you hold it, or if your pilot is good, will it energize the valve. The last thing is that your hi limit has failed, and is preventing your gas valve from getting any voltage at all on purpose, as it is a temperature actuated switch that will shut the fryer off it it gets too hot, it could have failed and is now keeping the pilot from coming on, some of these have a reset button you can push ( usually red ) that will reset it, but then why did it trip? either your thermostat is out of calibration, the bulb may be broken in the tank somewhere, or it may just be tripping too early, like 375, instead of 425 to 460 depending on spec.
Hope this helped, and thank you.
Dec 02, 2008 | Imperial IFS40 Deep Fryer
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Deep shut down
your themostat is either bad or your hi limit is bad if the oil gets too hot the hi limit will shut everything down for safety or if the oil temp is good it is the limit control shutting everything down when if should not first thing to check to see if the in the tank matches up to the knob if so change the hi limit it if not change the thermostat
Nov 13, 2008 | Cecilware FMS-40 Deep Fryer
GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 08, 2008 | Imperial IFS40 Deep Fryer
Kitchen Appliances - Others Logo
322 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
