Question about Video Cameras
I have a Sony DCR-HC52 camcorder that records on mini DV tapes. My computer does not recognize the camera when connected via the IEEE 1394 link. I have tried several different cables (both 4 and 6 pin), 4 different computers with XP and Vista, 1394 controller, and other solutions. None seem to work. I checked with Sony and they said no external driver is needed as it is included with Windows. I am running both SP2 and SP3 on different computers. Frustration has set in. Can you help?
  • 449 Answers
you can buy also for that in a surplus computer shop
or in computer shopping
not in online it takes you time to recieve it!!!
Posted on Sep 19, 2008
SOURCE: Connecting a Sony Camcorder to a Compaq Presario
Didn't actually find a solution. Looked at another HP notebook I have and found it has a 1394a port so I'll change computers.
Posted on Nov 29, 2008
old marine
  • 2058 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
  • 497 Answers
SOURCE: cannot capture video
Option 1:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 2:
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
  • 126 Answers
SOURCE: unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Posted on Nov 19, 2009
Lost cable to the computer for the DCR-HC52
Well you could use another cable that you can buy from Electronic shops and it's called the i-link cable or 1394 or Firewire. You have to buy the more durable ones which are more expensive as these work better.
Aug 27, 2011 | Sony DCR-HC52 Mini DV Camcorder
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
While capturing video from sony DCR-HC 40E via pinnacle 14 HD through IEEE 1394 in wondows 7, the captured video showed too many frame drops.
Sounds like time code breaks.
If you stripe the tape (record in one continuous run with the lens cap on and audio off) this will assist greatly.
Feb 17, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
How can I get Windows 7 Movie Maker to recognise input from my Sony DCR TRV18E Handycam?
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
Dec 27, 2010 | Sony Handycam DCR-TRV18E Mini DV Digital...
Is there any firewire port IEEE 1394 (FireWire/i.LINK)in sony hc dcr 52e
Yes, DCR-HC52E has IEEE 1394 port, it would be labled as iLink or DV
Check left to power jack.
Nov 25, 2009 | Sony DCR-HC52 Mini DV Camcorder
My Sony Dvcam DCR-HC15E Mini DV Digital Camcorder is not being seen when I plug it into the USB port on my computer. I have downloaded a program called Driver Robot which is supposed to update my computer...
Go to camcorder Menu and enable USB Streaming option.
Computer / Windows will recognize camcorder and will install drivers automatically for further communications.
Sep 18, 2009 | Sony Dvcam DCR-HC15E Mini DV Digital...
I have a Sony Handycam DCR-TRV720 Digital-8 Digital Camcorder. How can I transfer the video from these tapes to DVD? The cabling seems too old school to link up to my computer in order to burn a DVD.
This model has iLink: IEEE 1394 firewire port. If you don't have a firewire card, you can probably find one pretty cheap on the internet (try ebay).
Windows has movie maker, which when the camera is connected, will allow you to capture the video from the camera on the comptuer, although there is no DVD burner software at least on the XP version (not sure about Vista). I use Nero for the whole process: capture, edit, burn to DVD.
Sep 08, 2009 | Sony Handycam DCR-TRV720 Digital Camcorder
Nov 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Video Cameras Logo
185 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
