Question about General Electric GE DBVH520GJWW 27" Gas Dryer with 7.0 cu. ft. Capacity, Multiple Cycles, Sensor Dry and LED Cycle Co
Ge dryer model dbvh520gj2ww Place clothes in dryer..hit all the proper function keys press start to begin the cycle and nothing but click click click click....as it tries to spin. The dryer wheel spins by hand but when hitting the start button the dryer function will only make a clicking noise as it is trying over and over to begin spinning. Almost like a car battery that doesn't have enough juice to start a car. It worked fine yesterday....then bam today no go!
5 Suggested Answers
  • 10865 Answers
SOURCE: Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
Posted on May 07, 2009
  • 3074 Answers
SOURCE: i have a GE DCVH680
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 13, 2011
  • 2694 Answers
SOURCE: I have a GE electric
common problem is the rear bearing....http://www.youtube.com/watch?v=U7f8pF64008....copy and paste and watch the video,if this doesn't look like your machine,open the door and if there's two screws on the top remve them and pull off the top panel and everything else will be the same.
Posted on Apr 09, 2011
heatman101
  • 43501 Answers
SOURCE: The machine will not start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 23, 2011
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
GE Dryer bought 08/08/07 First it stop bewfore cloths were finished, if I hit start button it would finish, now it will not start.
The dryer knob on timer was cracked, when removed, therefore it was not actually engaging the
timer proper. Replsaced knob now it is fine.
Jun 03, 2009 | GE Dryers
Correct install of propane kit
perhaps it requires wet clothes to function properly .
Dec 25, 2017 | Dryers
No power or functionality - DOA
Ensure power is available to the unit, check the door switch for proper operation
Mar 23, 2009 | Dishwashers
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
General Electric GE DBVH520GJWW 27" Gas Dryer with 7.0 cu. ft. Capacity, Multiple Cycles, Sensor Dry and LED Cycle Co Logo
319 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal De
Are you a General Dryer Expert? Answer questions, earn points and help others
