Question about Mitsubishi Heating & Cooling
Galant '07 ac draining inside on passeneger side floor
  • 34 Answers
Drain is plugged up. Take a garden hose and flush drain from under car for just a second so as not to flood inside.
Posted on Oct 10, 2009
How do i locate the condensate drain in my mits galant 2000
For a 2000, it's more likely is that there's rust in the floor under the carpet. There are several drain plugs (approx. 30mm, actually filling manufacturing alignment holes) that often rust out. Fixing it requires that the seat be removed, the carpets lifted up and the rust cleaned / treated. New drain plugs can be made with some 20g steel sheet. They are usually pressed in, but can be glued with automotive gunk adhesive and sealed underside with stone guard spray. If there is real rust in the floor panel, cut out and reweld is required.
Oct 05, 2014 | 2000 Mitsubishi Galant
2001 galant inside leak when ac on
if the water is on the drivers side only ,you need a mechanic to put a gasket around the outside drain of the a/c this will stop the water from going back into the car.tell him to possibly use a material for windshield installation
Apr 17, 2014 | 2001 Mitsubishi Galant
2002 Mitsubishi Galant AC drain is clogged-WHERE is it???
The A/C drain is located on the bottom of the firewall on the passenger side. It should be easily found from under the car.
Jul 10, 2012 | 2002 Mitsubishi Galant
2002 Mitsubishi Galant has water draining into the
the ac drain is more than likley stopped up, they tend to get clogged with debri not allowing the condensation from the evap. core to drain properly, thus allowing it to leak into the floorboard.
Sep 16, 2009 | 2002 Mitsubishi Galant
99 galant leaks from behind glove box
there is a hose on the firewall that actually drains water from the ac system stick a screwdriver or a wire of some kind in this hose its easiest to get from under passenger side of car
Aug 03, 2009 | 1999 Mitsubishi Galant
01 Galant leaks water on the driver?s side floor boards
the ac drain is clogged up,so it does not drain outside,check pass.side-pull carpet away from fire wall and padding should be wet
Jul 30, 2009 | 2001 Mitsubishi Galant
Water leak on mitsubishi galant 1999
the probable cause is the drain for the ac coil is stopped up for an a/c leak inside.
if it smells like anti-freeze, the heater coil is leaking and may need to be replaced.
Oct 31, 2008 | 2000 Mitsubishi Galant
Heating & Cooling Logo
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
