Question about Sony Ericsson G705 Majestic Black OEM GSM Unlocked Cell Phone
I have sonyericson g704 and the navigation keys are malfunction when i sent it for repairs i was told i need to replace a cable that enable the navigation keys to work
    Sergeant:
  • 471 Answers
You may contact the service provider...
Posted on Oct 30, 2010
My acer aspire 5733 won't let me navigate to
f12 key may gone faulty, you need to attach a external key board
May 16, 2013 | Computers & Internet
My p990i flip keyboard 123 numeric and navigation key not working
Flip keyboard consist of flex connector inside and this could be damage due to fliptop mechanism that usually in used.malfunction of its key may result by cutting or breaking the flex connector and this is not repairable,possible to replace the flex connector and only service center can fix this problem.
Aug 12, 2011 | Sony Ericsson P990i Smartphone
Need password to use bluetooth on my samsung a920 cell phone
To turn Bluetooth on: 1. Select Menu > Settings > Bluetooth> Enable. 2. Press the navigation key up or down to select On and press to enable Bluetooth. To turn Bluetooth off: 1. Select Menu > Settings > Bluetooth> Enable. 2. Press the navigation key up or down to select Off and press to disable Bluetooth.
PW try these: 0000 000000 1234 123456
Dec 15, 2010 | Samsung MM-A920 Cellular Phone
The cd is not working and it says error03 what can i do the brand is 2004 mitsubish endeavor. this problem occurs 3 months ago. i don't know how it occur. i went to diller and they told me to buy new and...
Error 3/E-03 is a mechanical malfunction of the CD loading mechanism.
There is no do-it-yourself repair for this failure, it will need to be sent to a radio service for repair, or replaced.
Dec 13, 2010 | 2004 Mitsubishi Endeavor
2005 Navigator cant get it out of park? Button on side of gear shift wont budge when I push it in to try to reverse or drive
Does the brake lights work? If so try turning key forward just a little but not so far as to turn on lights, Try to move shifter then, If it moves? The shift interlock has malfunctioned, You can use that procedure to drive the vehical, Just do that and put in neutral and start the select your gearing, That way you dont have to tow it to a repair shop.. If the brake lights do not work? Check the fuse to it, If its good replace the brake light switch
Jun 13, 2010 | 2005 Lincoln Navigator
Hayward navigator is a piece of junk.
Try useing THE POOL CLEANER im in the pool industry and switched to these due to always having to perform repairs on the navigator
Jun 14, 2009 | Hayward Navigator Pool Cleaner
Navigation/keypad issue
you need to consult one of the S.E repair shop.It seems one of the flex cable damaged inside and need to replace it
Mar 28, 2009 | Sony Ericsson w580i Cellular Phone
Black LCD and out of focus
My LCD screen has also malfunctioned - some-one else has also posted a similar problem and has been told its to do with a carbon cable connecting the LCD screen to the camera that needs replacing.
Not sure about the viewfinder problem - is there a control to adjust the focus, or is that what you mean by the viewfinder lever?
Go to http://www.sony.co.uk/article/id/1218032872969 to register with sony for repairs.
Jan 25, 2009 | Sony HVR-A1U Camcorder
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Sony Ericsson G705 Majestic Black OEM GSM Unlocked Cell Phone Logo
178 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
