Question about Tommy Bahama Bahama Breeze TB344CW Fan
Fan clicks and their is a rubbing sound - Tommy Bahama Bahama Breeze TB344CW Fan
  • 715 Answers
Clean the top of the blades and check all screws are tight
Posted on Oct 08, 2009
I have a rattling noise on my 2.8 mitsubhishi pajero 1997 model.the noise is at the front of the engine. i checked the timing chain and guides they look ok and tight.when i rev the noise get quiet but when...
its likely the fan. if it sounds like metal clicking or grinding, its the fan bearings.
it could also simply be the plastic fan case rattling/rubbing against another hood accessory.
Mar 18, 2015 | 1997 Mitsubishi Pajero
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
Recently had fan replaced, now it is doing the same thing in heat and air cycles. when time for fan to come on to send air into the house it makes and aweful noise again and doesn't come on. Any...
Visually inspect the fan and the inside of the fan housing. It sounds like it's rubbing against something or is loose and therefore rubbing against something. May be as simple as adjusting and tightening a bolt or removing something that got into the fan housing.
Oct 27, 2013 | Coleman Heating & Cooling
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
I have a rooftop unit 10tons when i turn the fan on it makes a rubbing sound i remover the fan and the motor the motor make no noise I changed the berrings in the fan but it still makes the loud rubbing...
the unit may settled and it is rubbing against something it may be the cover...run the unit on low and see then to high that may lead you to the location good luck
Sep 08, 2009 | Heating & Cooling
Clicking sound as it revolves
If the fan is a ceiling hugger the wire connectors could be possiblly rubbing the motor
May 03, 2009 | Heating & Cooling
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Hi, i have an Bosch just over a year old and it has just recently started making a noise from the back of the unit. It sounds like a fan rubbing or rattling, it stops as soon as the fridge door is opened.
hi thanks for the question .It sounds like the fan in the fridge is rubbing locate the fan and clean out the obstacle thanks the appliance doc
Sep 29, 2008 | Refrigerators
My power box is making a clicking sound
by power box do you mean power supply? if so then the fan inside your power supply is probably clipping something as it rotates. I would suggest replacing it because if its not the fan then its failing. If you dont mean power supply just your PC, then it would be the same, a loose wire or something is rubbing one of the fans inside the case, either a cooling fan or the cpu fan.
Aug 06, 2008 | HP Computers & Internet
Tommy Bahama Bahama Breeze TB344CW Fan Logo
52 people viewed this question
Top Tommy Bahama Dryers Experts
Dan Webster
Dan Webster
Are you a Tommy Bahama Dryer Expert? Answer questions, earn points and help others
