Question about Kitchen Ranges
How do I change a stove and oven from natural gas to lp?
    Scholar:
  • 121 Answers
Call a plumber. He can install the adapter necessary for this conversion.
You can also check at your local DIY store and ask if they have the conversion kit. The sales associates can also give you some valuable advice on how to do it.
Posted on Oct 08, 2009
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
Change over to LP on whirlpool oven
All ovens come from the factory set up for natural gas. To convert to liquip propane you must change the orifices. Once you have the proper orifices, you will be able to make the adjustment you desire. You can contact your lp supplier and have them send their techie out as they do this as a free service.
Apr 07, 2009 | Kitchen Ranges
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
