Question about Troy Bilt Tuffy 4.0 Hp Rear Tine Tiller
Can not push tiller when engine is not running. Works fine if engine is running.
  • 715 Answers
Dis-engage transmission
Posted on Oct 08, 2009
2 Suggested Answers
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Engin runs fine at idle but stalls out at high idle and wont rev up.
Hi 5flash... Get an assistant and a can of starter fluid. Remove the air cleaner and spray some starter fluid into the air intake. Start it up and spray the starter fluid as you move it to high idle, repeat until it works properly. Joe
Thanks for choosing Fixya!
Feb 22, 2011 | Mantis 2-Cycle Tiller
Cannot get full throttle out of honda fg100 tiller engine
I have the same FG 100 tiller with the same problem. I did replace the carb with a brand new one and still can not get full RPM. It does try to go to full RPM, but drops back. I even checked the transmission and clutches very thing works very well.
Jun 26, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
How do you start a 2 stroke Mantis? I lost the book. Will
first, push the primer bulb a few times to get fuel circulated and air out of the carb. Turn on the switch, put the choke on full. Pull the rope until you hear it fire. Then put it on half choke. Pull the rope; it should fire within a few pulls, and should run. Take the choke the rest of the way off once it's running well. This is a standard starting procedure that works well for every kind of 2-stroke engine used in the garden.
Mar 28, 2010 | Mantis 2-Cycle Tiller
Mantis tiller won't run
No it will be fine. You would be surprised how many 2 cycle tillers Ive worked on where people put strait gas in them. they dont run long enough with strait fuel in them to do any damage. I hope this was helpful.
Aug 07, 2009 | Mantis 2-Cycle Tiller
The engine cuts out after it heats up
This seems to be a common issue as of late, i'd tighten up your idle adjustment so you can run at full throttle with no issue. The tiller's oil should be at the lower lip of the dip stick's access threading while the unit is laying face down (gas tank down). Clean up your carb as well and change your plug/filter, if this doesn't work than you're probably looking at some simple carb adjustments, but the fact it dies after 10 minutes of use makes me think it's running either dirty or too rich.
Apr 19, 2009 | Honda 25cc 4-cycle Mini Tiller
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Troy Bilt Tuffy 4.0 Hp Rear Tine Tiller Logo
61 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
