Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
My printer will not print jobs from computer , it will make copies and it will fax but when I click on the icon to print nothing happens. I just put a new ink cartage in. I tried the test page and it printed out. (hp officejet 4215 all-in-one) Juanita
  • 37 Answers
Right click on the printer icon in the Printer and Faxes menu. Make sure in the pop up box it says USE PRINTER OFFLINE. If it says USE PRINTER ONLINE, click on it and then try printing again. You may also want to double click on the printer icon and make sure there is nothing scheduled for printing. If there is, cancel it and try printing again. If that doesn't work, make sure you have the correct driver selected and it is connected to the right port.
Posted on Oct 08, 2009
Epson scan when the scan icon is clicked nothing happens
Simply re-install the drivers it is the problem of some dll files or in second case your printer driver is not compatible with win7 so run the application in compatible with lower OS my clicking the icon go to the properties and run in compatible mode choose winxp
Aug 05, 2012 | Epson Stylus Office Bx635fwd Inkjet Copy...
It just won't work. The light is green but I send a document to the printer and nothing happens. When I turn it on the light is red but if I put the "job cancel" button it will got to green.
Go to "Printers and Faxes" in the "Control Panel" and check to see if your printer shows any documents waiting to be printed, Cancel these documents and Right click your printer icon
select "Properties" and select "Print Test Page" to test your connection...For varies reasons documents sometimes fail to print and the printer queue backs up
Feb 22, 2011 | Computers & Internet
I just created a new document, and when i push print, nothing happens except printer gives me a copy of something else. how do i get my printer to print the new page? thanx, babawawa1
go to printer and faxes and look to see if there are print jobs "stuck" in there. If so,click on documents and delete all print jobs. Then as an extra precaution, right click on "My Computr" and select manage..go to services and applaications..select services..drill down and find "Print Spooler" and stop and restart the service. Try your print job again
http://www.aa1consulting.com
Jul 26, 2009 | Lexmark C533DN InkJet Printer
7310 wont print
u have to clear the sent job, go to printers and faxes through your start menu, if u cant find it there, go to control panel, double click on the printer and faxes icon, on the pop up window, double click to open the printer then select all the jobs and empty the box, then you can start using again, make sure the printer is off while doing that.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
Cant print
First of all the basics to copy only you need to press the copy button in the printer itself, to print you will ot have to press any button in the printer.
Try the following Steps.
First if you have a windows operating system
Go to Start> Settings/Control Panel> Then Printers and other faxes and see how may printers icon do you see listed there, if you have multiple and unwanted icons then the printer you have delete all the icons there.
And insert the All-In-One Printer CD to the computer
Unplug the USB cable from the computers end and wait for a while until it says found new hardware and wait till all the drivers are installed
Then check in printers and faxes window there should be a new icon listed and it should say 0 Ready.
Now right click on the printers icon>Go to> Properties and click on Print test page.
And when ever you print any document make sure in the window you have the right printer listed
Jun 23, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP C1480
Please perform the below steps to clear the queue and print from the computer.
Before performing the below steps try to make a copy from the all-in-one to check the hardware functionality.
Remove the USB cable from the computer.
Now click on start --> control panel --> printers and faxes --> right click on the HP C4100 printer icon and delete all the pending documents.
Now again click on start --> run --> type services.msc and press enter --> locate print spooler in services window and right click on the print spooler and click on refresh or stop the spooler service and then restart the spooler.
Now open the printers and faxes folder, right click on the printer icon --> properties --> advanced tab --> enable print directly to printer and click OK.
Now connect the USB cable back to the computer and then try to print from the notepad and check for the result.
May 29, 2008 | HP Photosmart C4180 All-In-One InkJet...
No printing...?
Make sure after you click 'print' that the printer you are printing from is not the 'fax'. I had this happen too... just a suggestion ;)
Apr 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
