Question about Ovens
Can i replace my oven element from 1400 watt to 2000 watt ?
  • 6,784 Answers
NO, This will cause a major voltage spike and may short the main circuit breaker in some cases. I recommend replacing the original element with the equivalent wattage rates.
Posted on Oct 08, 2009
Electric heating not working
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Mar 31, 2015 | Ovens
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
We have a 2 and a half yr. old Frigadare oven and the element went out. we bought a new one (gave them the model number) and the new element is so skinny than the original one. I turned the oven on to 375...
When you replace an oven element you must replace it with an element of the same rating. Say the original was a 2400 watt element. You could probably get away with a 2200 watt replacement element. You would not put an 1800 watt element in as a replacement. It wont heat up as much, particularly if it is a big oven. I would check both ratings first.
Feb 28, 2011 | Ovens
I need to replace a bake element for a 1950's GE Oven (Model # D14X1DC) but the exact volts and watts for a element are hard to find (236 volts, 3000 watts). Do the volts and watts have to be exactly the...
I found a website that helped, here are some model numbers that work for the GE element. ERB44X126 , Ch44x126-450546 these work for the 3000 watt 236 volts. hope this help.
Nov 07, 2010 | GE Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Bake element fell apart. Changed it out with replacement element (Emerson CH 5862 PCN 458580, 240Volts, 2800 Watts) Still does not work.
As a general rule, when you change an oven element, you should change the thermostat as well as the element failing can sometimes take out the thermostat as well. (Info. courtesy of a NEFF engineer many years ago as they always change both if an element fails).
If you haven't done so, I would suspect the thermostat.
Feb 06, 2010 | Ovens
Maytag electric oven will not come up to temp., heats to 170 but no higher. Clicks like it wants to raise temp. but it will not go up. Model # MER5775QAF. Serial #18808572GL.
Usually the element burns out. It may have "3500 watt element but only producing 2000 watts". It's not completely out, but not far from it.
Jan 07, 2010 | Ovens
Hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Mar 19, 2008 | GE JRS06SKSS Electric Single Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Ovens Logo
220 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
