Question about Samsung CLP-550N Laser Printer
Where is the reset fuse located on the Samsung CLP550N printer?
    Genius:
  • 1,018 Answers
A fuse should never be a resettable device on a product. Fuses are made to open if there is an over temperature situation or an over current situation.
Reset is normally controlled by a button sequence on the front panel.
Can you please provide a full description of both the failure and the "Fuse" description for me?
Don
Posted on Dec 09, 2009
Samsung CLP550n. Insert Magenta.... what exactly the problem is? And how to solve?
The printger is reporting that the Magenta color toner is empty and needs to be replaced.
Just remove the old one and install a new one.
Don't forget to rate this answer if it heps.
www.labellpcsolutions.com
Jan 18, 2011 | Samsung CLP-510N Laser Printer
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Where is the fuse on the samsung ml-2010 laser
which fuse at you looking for. if you are looking for the fuser that will be the item behind the printer. open up the back door you will be able to see the fuser.
if you are looking for the electric fuse. that will be on the main boad. it is right behind too. open up the back cover you will be able to locate the fuse.
May 20, 2010 | Samsung ML 2010 Laser Printer
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
I refilled my sf 565 pr machine, but after refilling it is still showing me low toner
First time
I am not clear what was toner refill your printer.
Other brand I mean hp/canon.It is not supported toner for samsung.Try first time clean drum.If it not fix may be change toner cartridge.
Mar 04, 2010 | Samsung SF-565PR/XST Printer
Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Feb 12, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung clx 3175 toner chip overide/reset?
we use chip and fuse for samsung cartage reset when it give us cartage empty message. before geetting thish we gets tonner is low .if recently we filled samsung dust/powder/tonner in cartage we no need reseter. in my practics while i need to put fuse (reseter) i put iton cartage after resetin suddenly i putout it from cartage and use old fuse. in this way we can use or not green chips? actuly it is difficult.
Jun 11, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Apr 24, 2009 | Office Equipment & Supplies
Samsung scx-4300 toner exhausted
samsung scx-4300 error message "toner exhausted" how to reset printer
Apr 11, 2009 | Office Equipment & Supplies
Samsung CLP-550N Laser Printer Logo
69 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
