Question about IOGear (GBU211) Bluetooth Wireless Adapter
Vista and bluetooth
I keep getting error that says passkey exchange failure does anyone know what I can do to fix that. I have tried chosing a passkey, letting system chose passkey and nothing works.
  • 556 Answers
Passkeys need to match in both the router/access point and the wireless adapter attempting to communicate with it. Whoever configured the router should be able to supply the WEP/WPA passkey / passphrase / network key If your router does not have a passkey ... you are attempting to attach to the wrong wireless router. (if that is the case you should consider assigning WEP/WPA security to your wireless networl (router/accesspoint and adapters)
Posted on Dec 24, 2007
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
Lost my plantronics 222 bluetooth passkey
trying to install my plantronics 222 blue tooth head-set to my nokia 7610,but it keeps asking for a pass code.
Oct 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Logitech dinovo bluetooth keyboard passkey issue
You entrer your own passkey after hitting the connect button on the KB.
May 28, 2009 | Logitech diNovo Edge Bluetooth® Wireless...
Bluetooth headset won't connect in Vista
I had a similar problem. First part of the solution is to disable the headset profile for the headphones. These headphones can't handle both headset and headphone profiles at the same time. Second part of the solution is to make sure that your headphones are on when you activate bluetooth on the computer. For some reason, Vista doesn't like setting up the initial connection on-the-go, so it will just act like its connected and move on. Hope this helps!
Dec 07, 2008 | Insignia Bluetooth Wireless...
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
LOGITECH BLUETOOTH MOUSE
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Dec 01, 2007 | Logitech 931249-0403 Mouse
Motorola i870
Try 0000 ...  That seems to be a "common" passkey for BT headsets...  That's Four Zeroes...
DLC
Oct 08, 2007 | Motorola Mobility H500 Wireless Headset
IOGear (GBU211) Bluetooth Wireless Adapter Logo
136 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
