Question about Acer Aspire 5500 5570-2609 Laptop
Error appdata I installed registry mechanic to my laptop wich i have vista basic so i uninstalled it after i did that my laptop has the old grey destop view i've tried going to my taskbar and ghanging it but that didn't work so how can i get my new vista look back (black color look) instead of the grey classic view i also get an ''error appdata'' and i can't even upgrade to IE8 wich i had before. Please help!
  • 121 Answers
Sounds like you have sum spyware malaware or trojan on, google the following programs, kaspersky, xsoftspy, malaware, tune up utilitys 2009 will fix it, if it doesnt re install windows
Posted on Oct 10, 2009
How to delete pc optimizer and fix registry errors
Try to uninstall the pc optimizer from add\remove programs in control panel. In case it is not getting uninstalled due to log file or unistall not available, Install the PC optimizer again and overwrite on same location where it is installed and then uninstall. PC optimizer will definately be removed. For registry error, you can try softwares like system mechanic, registry mechanic etc.
Jan 25, 2012 | Dell Computers & Internet
HP Officejet 4315 will not scan with OCR using Vista OS - will scan image not text - %APPDATA%\HP\Digital Imaging\Data\Destination in registry OK - installed Vista tablet path for HP - uninstalled and...
Your problem always makes me wish you opeted for chat and I got lucky enough to be in line
So call (805) 452-2733 and I'll make your printer work on Vista
I'm up anyway but just don't wait all night LOL
Oct 06, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Runs for about 5mins and screen goes grey
Uninstall unwanted Programs: Unwanted programs installed oncomputer may cause Slow Windows XP issue on your computer. The best way to fixthis problem is to remove unwanted programs from your computer. Here are steps: 1. Click on Start button on thetaskbar.
2. Click on Control Panel.
3. Double click on Add or Remove Programs.
4. Select the application which is not in use.
5. Click on Remove button.
6. Follow simple instructions.
7. You are done. b> Update drivers: Outdated drivers often result inslow performance of PC. What happens is that duplicate keys are created whenprograms are updated or reinstalled. It is always good for your computer tokeep your device drivers updated. b> Why Windows XP Lags? Cluttered or fragmented registry isroot cause behind Slow Windows XP . When registry is cluttered the XP wouldresult in poor program executions, freezing during load time and it alsodecreases overall PC performance. Damaged entries in registry also cause Javascript errors, Windows errors and blue screen errors which are extremelyharmful. b> How to clean your registry?: The best way to clean your registryis to download and utilize a good registry cleaner. This software will scanyour registry for errors, corrupt keys and links, duplicate and unneeded files,and it will fix and eliminate what you need, all at the click of a button. Agood registry cleaner such as RegInOut will also defragment and organize yourregistry, recover lost keys, and perform regular scheduled scans to keep yourregistry into shape.
May 15, 2010 | Acer TravelMate 2355 Notebook
When i try to load itunes I get a %APPDATA%\.
OK...i just fixed my itunes and firefox...everything is working FINE now
follow the link's steps http://support.microsoft.com/kb/886549 and for that last table i just left mine as %PUBLIC%. Just make sure the lines match.
then follow this link to uninstall itunes and its components http://social.answers.microsoft.com/Forums/en-US/vistaprograms/thread/5f909d31-1b10-42a4-a820-af653061baaf/?prof=required.
you have to make sure everything that has to do with itunes is uninstalled then restart and install again.
everything should work.
Apr 28, 2010 | Apple iTunes
Error 1606
Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
The response to "Echo %appadata%" should be
C:\Users\UserName\AppData\Roaming
A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
Also check the key
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
The value of this key should be
%USERPROFILE%\AppData\Roaming
More keys to check:
HKCU\Volatile Environement (1)
HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Volatile Environement (1)
The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
is C:\Users\Murray Admin\AppData\Roaming
In the key the key
The value for AppData is %APPDATA%
The value for Local AppData is %USERPROFILE%\AppData\Local
In HKCU\Volatile Environement (1)
The value for HOMEPATH is \Users\Murray Admin
In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
%APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
All the other values within do contain %USERPROFILE%\
Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
is about six months old. Both are from the same manufacturer (Compaq) but different models.
Also - Using the set command the value returned for %APPDATA% are:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Murray Admin>set
TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
TMP=C:\Users\MURRAY~1\AppData\Local\Temp
Jan 20, 2010 | HP Computers & Internet
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
UNABLE TO UNINSTALL PROGRAM
you probably uninstaled it, but didn't remove it from the registry properly... try searching the registry on: Start > Run and type Regedit, and go to search, and type SmartBro... yuste delete those keys and reboot...
warning! backup your registry before you make any changes!
Jan 15, 2009 | Microsoft Windows Vista Ultimate Edition
Quicktime will not load on vista laptop dv9626us HP
hello, the quick time player installer you are trying to install is corrupt.
Jan 12, 2009 | Microsoft Windows Vista Home Premium with...
Hey there, I was trying to
I guess I found a solution for the problem.
I also got this error message after installing ControlCenter3. Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907. The numbers at the end can change, but that's not important.
I have two laptops running vista. I got this error with the 1st laptop. Then I tried it with the second laptop, it worked fine. That made me think: On the first laptop I had tried to install the ControlCenter3 from the CD, but it turned out that the CD did not support Vista. Then I got the vista driver/ControlCenter3 package from the Brother website. This is the one that did not work on laptop one. What I then guessed was, that I had some ugly remains from the installation of the old driver (not for vista). I started cleaning the registry. First of all I run the driver uninstall program from Brother (free from their website) then I cleaned the registry with CCleaner (freeware). Still that was not enough. I started the regedit program and started searching for the term Brother. It was still there in about 10 or more places. I deleted all records that were connected with my brother printer (a DCP-130C). Then I run CCleaner once more. Then I installed the vista driver package (from brother website). Restarted and voila: it worked. ControlCenter3 workes fine now. I started the ControlCenter3 update (also on brother website) and finally with the scanner utility put the scanner resolution limit up higher. That's it.
Before working with the registry make a backup, please.
This procedure should also work for other brother printers using the controlcenter3. It should also work for other systems than vista.
Cheers, hope this was helpful.
Edi
Jul 15, 2008 | Office Equipment & Supplies
Acer Aspire 5500 5570-2609 Laptop Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
